No Servospeed With SSC32
I discovered something tonight, while using the "servospeed" in a script.  I have a servo sonnected to D0. Got the servo to move fast or slow using servospeed just fine per the instructions. Then, with a SSC32 controller, and the same servo now connected to V0, the servo moves at one speed only, The servospeed command has no effect either way. So Im asuming that has something to do with the SSC32 maybe?
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills.
The ssc-32 does not support servo speed.
Thanks DJ,  I assume that also applies to when creating Auto positions ?
#3   — Edited
The speed, yes. Not the steps and delay as they still work.
servo speed Capability is not supported on  ssc32
Ok, cool.  good to know:)  Thank you again .
