Pandorabots icon Pandorabots — Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots Try it →
From what I've heard and experienced, NIMH batteries don't last that long and their shelf life is pretty poor too. Although they are cheap and readily available... but don't be fooled, any battery can start a fire if misused, use them right and they will be fine.
my main concern is i can't take batteries out to charge,robot (security bot)will be in house where no one is
I don't plan on taking my batteries out to charge either. I'm connecting the balance lead to the balance charger, mounting both in the robot and then will make a cable to run from the balance chargers 12v barrel jack up to the barrel jack on the back of the robots body where I'll plug in the 12v supply (or have the robot do this itself eventually).
I'm tempted to fit a lipo charging bag inside too for security but from what I can gather it's only paranoid people posting about dangers of lipos and only dangerous if not used right.
I had the same thought about using that barrel jack. I don't foresee modding for self charge until I get back to the states so that's what I will do as well.
@RichMR2 that is what i was thinking but cant find any lipo chargers that will start charging right after you plug power to them. Everyone i see you have to press buttons on display to start charging. Or am i wrong?
thanks that is perfect because i will have 3 battery packs 1-motor 2-ez 3-ip camera
Why not power them all from the same source? That's what I do for the EZB and motors in my build (and soon to power 6v to to servos direct from battery too). You can link more than 1 pack together in parallel to make it bigger (as in more power, 2 x 5000mAh lipos in parallel make 10000mAh) and then you wont end up with one pack being drained faster than the other two.
That is provided all 3 items can handle the voltage, I've had to fit a lipo 5a 6v regulator for the servo circuit but motors can handle 7.4v (so far at least no problems) and so can the ezb.
According to hobby king these chargers only use 800mA so you can power 4 or 5 of them from a 12V 5A supply and charge 5 batteries at once.
How safe all that is I have no idea, it is next on my to-do list to look in to all of that but am waiting on a few things to arrive for the build before I get hands on again (have other work that needs doing to pay for the robot habit)
