Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
New Part
hi all.
averyone knows the great part nieks have design for to get jd body on to the rolli. now i was thinking similar part but double to use it for jd to connect the pigtail, on its back.maybe its a creepy idea but i seem to like the idea. so i thought ask others there opion.i also wanne have jd whit elbows so he can turn his , grippers and grab more items that are lying down. and last thing is how to get waist turning too.so a combination off all this together will, make jd the most movelble robot ever.
Hi Nomad,
I can model and make the parts for you no problem. PM me and we can get them sorted for you. I would probably be doing them for my JD too !
Best wishes,
Jay
I know you were just thinking of those you showed us but, I think, switching the male for female connector ends would be cool on all of the EZ-Bits. Like a Bizarro version. That would be awesome. Great idea Nomad. Thanks for sharing.
thank you for telling.i had another idea;whits will provide lot off building possebility's, to make more other chapes in robots. 1 -two male together 2 -two females together 3 -1 male 1 female together 4- two females crossed
Yep that's what I had envisioned as well. I doubt EZ-Robot Co. is ready to deal with another set of parts but it would be cool if someone made this happen. My 3d modeling skills are at a very novice level so I won't volunteer but I may give it a try some time, if I find the time.
i found a volunteer.in the first pic,that part will lift jd's arms up and there comes a servo in. so he can turn his body left&right.:D here two pics.1 whithout turning&1 whit.
