TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
hi RR ,wouldn that point the sensor upwarts?
wow yourre all typ fast ok i understand dj second line ,block on servo.
thank you bolt
It won't point upwards take another look... then look at the Ping bit and then Roli's chest... The Ping will sit on top or bottom of the cube that's attached to Roli or JD's chest and face forward....
ah the cube makes an angle.:)
for the sonar i like it,but for the rgb,i will make another back plate due to , the cube is 3 cm long.
