My web-browser stops working while I'm trying to connect my robot to ARC. On my HP full-ver win-10, OS ve 15063.674, Browser won't load pages after doing a tutorial. fix only for windows full-ver. not upgrade.
WARNING, requires restart. resets net-drivr. favs stay, no changes.only brings your browser back when Win-10 full-ver browser stops working. right-click start left-click task-manager left-click file left-click run new task left-click in the open field type cmd left-click check-box "Create this task with administrative privileges" left-click "Ok" type at the blinking prompt netsh int ip reset press enter wait when done, type exit press enter Computer will be back where you were. reboot.
takes 20-seconds longer to load stuff again. now ur back where you were.
jeremie, charger fixed. cold-solder joint in wall-wart, put out 6-volt. Fixed now Vout=12V. Connect issue related to print-server=fixed i connect now. all those weird symptoms from that. problem was windows full as it loads.
@Doron Great to hear! I'm very impressed that you were able to track down and remedy both issues, nice work!
