Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
My Windows-10 Web-Browser Stopped Working
My web-browser stops working while I'm trying to connect my robot to ARC. On my HP full-ver win-10, OS ve 15063.674, Browser won't load pages after doing a tutorial. fix only for windows full-ver. not upgrade.
WARNING, requires restart. resets net-drivr. favs stay, no changes.only brings your browser back when Win-10 full-ver browser stops working. right-click start left-click task-manager left-click file left-click run new task left-click in the open field type cmd left-click check-box "Create this task with administrative privileges" left-click "Ok" type at the blinking prompt netsh int ip reset press enter wait when done, type exit press enter Computer will be back where you were. reboot.
takes 20-seconds longer to load stuff again. now ur back where you were.
thank you, sir.
You didn't mention what web browser you are using ... FYI if you connect directly to your ezb4 with wifi (AP mode) then you will lose internet. In AP mode you cannot connect to the internet and the ezb4 at the same time (unless you use a network (RJ45) cable or a extra wifi dongle... In Client mode however, your ezb4 is connected to your router instead of directly to your laptop. It becomes part of your network. In Client mode you can connect to the ezb4 and internet at the same time... If you still prefer to use AP mode or don't have a router (as mentioned) you can buy a cheap usb wifi dongle off of ebay. Then you can connect to the internet (using either the dongle or the inbuilt wifi) and the ezb4 at the same time (without needing a router in client mode)...
See here... EZB4 wifi modes
fox, edge, chrome, explr, netscape. comms with Builder "connect" button. This post intended for win-10 ful-ver not the upgrade kind.
command is: netsh int ip reset related to Network server not browser you use.
If you have router that shares the same 192.168.1.1 default IP address as the EZ-Bv4 you could have a conflict when you are connected to the EZ-Bv4 and wired ethernet at the same time. @Doron, please try unplugging your wired ethernet for a moment and see if that clears things up.
I would start with a default AP mode connection and get acquainted with your robots first. You can find the instructions for building the robots within each ARC Example Project for the specific robot you have so you won't need access to the internet right away.
Once you are well oriented and you'd like to read the online documentation and control your robots at the same time I would recommend what @Richard R was mentioning, use client mode. Here are a few places to get more info on client mode:
EZ-Robot Tutorial
Cardboardhacker's Tutorial
*Edit: @DJ has a better link:) I was writing at the same time as he was lol.
did that no hlp.
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: Windows version: Microsoft Windows NT 10.0.15063.0 Screen Resolution: 1280x1024 (96x96 dpi) Version: 2017.10.04.00 Attempting connection on 192.168.1.1:23 Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZB.f9xEF7cNHr(Int32 , Byte[] cmdData) BbytesToExpect: 1 U Received: 0 Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.iNmEWh1QIN() at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
ez-bv4 reports SSID: EZ-B v4 00078033D22C Protocol: 802.11g Security type: Open Network band: 2.4 GHz Network channel: 1 IPv4 address: 192.168.1.2 IPv4 DNS Servers: 192.168.1.1 Manufacturer: Ralink Technology, Corp. Description: Ralink RT5390R 802.11bgn Wi-Fi Adapter Driver version: 5.0.57.0 Physical address (MAC): ?B8-76-3F-36-58-CE Disconnected
Robots can't do much when things get fringe.
