Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Minor Installer Bug
@DJ Sures, here is one for your rainy day list.
After I install ARC, either on Windows 7 or 8.1, I pin the app to the task bar. Every time I update to the latest version, the icon on the task bar turns to a blank white icon and when I click it I get an error message that the application has been moved or removed, and I need to unpin and re-pin ARC.
Other applications I have pinned to the task bar don't do this.
well it seems am not good in conversations.
sorry about that alan
@nomad18.08 Not a problem. I understand the language barrier can occasionally cause you to miss things. you read and write English better than I read or write any other language.
@Wolfie, Not every program, but I think it might be every program that has it's install package created by recent versions of Microsoft Visual Studio (although oddly enough, not any part of Microsoft Office).
I believe this is something that is fixable by DJ but for the time being the white page will appear everytime you update. This is because the shortcut icon in the task bar is linked to a specific URL along with registry code if I understand correctly. When you update these change and the installer doesn't update the shortcut in the task bar because it doesnt know it is there.
