Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
France
Magnetic Battery Charger
Hi all,
I would like to make an autonomous robot system with a charging simple, effective and safe for children. And I imagined this: an AC adapter that I can plug a USB cable magnet (which is used to recharge the lamp P5R). Its magnetic end allows him to connect perfectly to the extremity of the lamp for recharging.
Battery boutique.ledlenserfrance.com/Accessoires-Piles-lampes-LED-LENSER/90-Blister-batterie-rechargeable-Led-Lenser-P5R.html
USB cable www.ledlenser.pro/c116-nouveautes/216-cable-usb-pour-recharge-led-lenser-p5r.html
Charger https://www.ecologeek4u.com/catalogue/chargeurs/chargeur-adaptateur-220v-vers-usb.html
In your opinion:
  • This system is viable? How can we improve?
  • Is it possible to put a battery 9 or 12 volts (not 3.5 volt)? Which model do? Such a cable can be used? What do you think?
Thank you
Jerome
@Robotmaker , none of your posts are showing up in any threads. I see your name on the Thread Title on the front page but they are not showing up in any threads. You need to contact support to find out why. Till then maybe you should stop wasting your time posting. I don't think anyone can see them.
Dave, I wondered the same thing, why can,t I see any robotmaker responses? Your threads are not showing? Steve S
