Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
MEGA STEPS AND BEARING FAILURES
Hi @Athena,
I'm running an ARC project on an EZBv4 that manages an Arduino Mega (motor control) and a Teensy 4.1 (servo/sensor control). The Mega and Teensy each run firmware (posted below) and are paired with corresponding UART Robot Skills in ARC: MEGA_MGR_v7 (for the Mega) and TEENSY_MGR_v2 (for the Teensy). I have included the firmware and skill code below.
High-level setup / connection model:
  • ARC (on the PC) connects to an EZ-B v4 (EZBv4).
  • The Arduino Mega and Teensy 4.1 are connected to the EZBv4 UART(s).
  • ARC accesses each controller via separate UART Robot Skills (MEGA_MGR_v7 and TEENSY_MGR_v2).
  • MEGA_MGR_v7 parses/constructs a binary packet protocol (header 0xA5). MEGA_FIRMWARE_v6 expects RSP_TOTAL_STEPS (0x11) to be sent on stops.
  • TEENSY firmware uses an ASCII packet format like "$PAYLOAD*CHK\n". TEENSY_MGR_v2 parses lines and currently prints REPL results; TEENSY_MGR_v2 contains placeholders where ARC UART ControlCommand calls should be used to read/write to the EZB UART.
Summary - Mega side
  • Firmware: MEGA_FIRMWARE_v6 (Arduino Mega)
  • Robot Skill: MEGA_MGR_v7 (UART robot skill in ARC)
  • Responsibilities of MEGA_FIRMWARE_v6:
    1. Receive WayPoint data.
    2. Receive Pivot data.
    3. Receive STOP command.
    4. Receive actual bearing updates.
    5. Send STOP command.
    6. Send obstacle-detection scan requests at required intervals (step counts).
    7. Send STEPS whenever a STOP command is sent or received.
    8. Send periodic updates of desired bearing when desired bearing changes by 1 degree.
    9. Count STEPS and STOP when Pivot Data limits are reached or combinedStepsDesired is reached.
    10. Count STEPS for obstacle-detection scan intervals and send the scan request.
    11. Control motors based on the differential between desired and actual bearing.
    12. Compute desired bearings if WayPoint data indicates bearing_alignment = 1 (offset reflector position).
Problem #1 (Mega) When the system stops, no STEPS (TOTAL_STEPS) are printed to debug (item #7 above). Can you troubleshoot why reportStepsOnlyOnStop() / RSP_TOTAL_STEPS are not being observed by MEGA_MGR_v7 in ARC?
Summary - Teensy side
  • Firmware: TEENSY_FIRMWARE_v4 (Teensy 4.1) including PacketHandler
  • Robot Skill: TEENSY_MGR_v2 (UART robot skill in ARC)
  • Responsibilities of TEENSY_FIRMWARE_v4:
    1. Sweep servo left/right searching for a reflector.
    2. Detect reflector-search runaway and send a STOP command to TEENSY_MGR_v2.
    3. Compute actual bearing updates and send them to TEENSY_MGR_v2.
Problem #2 (Teensy -> Mega) As actual bearing updates are generated by the Teensy firmware + TEENSY_MGR_v2 combo, they need to be forwarded to the MEGA firmware + MEGA_MGR_v7 combo. That data flow is not working reliably. Can you troubleshoot why bearing updates sent from the Teensy / TEENSY_MGR are not reaching the Mega / MEGA_MGR?
Notes / additional context for troubleshooting
  • Both MEGA_MGR_v7 and TEENSY_MGR_v2 are implemented as UART Robot Skills in ARC and parse/build binary or text packets respectively.
  • MEGA_FIRMWARE_v6 uses a binary packet protocol (header 0xA5) and expects RSP_TOTAL_STEPS (0x11) to be sent on stop events.
  • TEENSY firmware uses ASCII packet format like "$PAYLOAD*CHK\n". TEENSY_MGR_v2 parses lines and prints REPL results; TEENSY_MGR_v2 contains placeholders where ARC UART ControlCommand calls should write/read to/from the EZB UART.
  • The EZBv4 is the EZ-B controller that ARC connects to; the Mega and Teensy communicate through the EZBv4 UART(s). The setup implies the Mega and Teensy are connected through the EZBv4 serial interface(s) that ARC accesses via UART Robot Skills.
I have posted the applicable code below. Thank you - Jack
MEGA_FIRMWARE_v6
#include <AccelStepper.h>
static const uint32_t BAUD = 115200;
static const uint8_t UART_HEADER = 0xA5;
#define LINK_SERIAL Serial3
#define DBG_SERIAL Serial
// Commands from ARC / MEGA_MGR
enum CommandId : uint8_t {
  CMD_STOP_MOTORS = 0x01,
  CMD_ACTUAL_BEARING = 0x03,
  CMD_RIGHT_PIVOT = 0x04,
  CMD_LEFT_PIVOT = 0x05,
  CMD_WAYPOINT_DATA = 0x06,
  CMD_RESUME = 0x07,
  CMD_PAUSE = 0x08
// Responses to ARC / MEGA_MGR
enum ResponseId : uint8_t {
  RSP_NAV_ACK = 0x10,
  RSP_TOTAL_STEPS = 0x11,
  RSP_DESIRED_BEARING = 0x12,
  RSP_OBS_SCAN_REQUEST = 0x13,
  RSP_READY = 0x14,
  RSP_STATUS = 0x15,
  RSP_ACK = 0x16,
  RSP_NAK = 0x17
// Stepper motors
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
// Motion state
enum MotionMode {
  MODE_IDLE = 0,
  MODE_PIVOT = 1,
  MODE_TRACK = 2,
  MODE_PAUSED = 3,
  MODE_COMPLETE = 4
MotionMode mode = MODE_IDLE;
MotionMode resumeMode = MODE_IDLE;
bool motorsEnabled = false;
bool systemReady = false;
// Waypoint / leg data
uint32_t pathTotalDistance = 0;
uint32_t combinedStepsDesired = 0;
uint32_t oppositeDistance = 0;
uint8_t bearingAlignment = 0;
uint16_t desiredBearing100 = 9000;
uint16_t actualBearing100 = 9000;
uint8_t trackDir = 0;
uint32_t scanIntervalSteps = 3056;
// Runtime
uint32_t totalStepsTaken = 0;
uint32_t lastReportedDesiredBearing = 0xFFFF;
uint32_t lastReportedStepsOnStop = 0;
// Leg tracking
uint32_t legStartSteps = 0;
uint32_t nextScanAtSteps = 0;
bool legLoaded = false;
bool scanPending = false;
bool stopJustOccurred = false;
// Motion control
int wheelSpeedBase = 1600;
int leftTargetSpeed = 0;
int rightTargetSpeed = 0;
int leftCurrentSpeed = 0;
int rightCurrentSpeed = 0;
int speedRampStep = 25;
// RX parser
uint8_t rxState = 0;
uint8_t rxCmd = 0;
uint8_t rxLen = 0;
uint8_t rxIndex = 0;
uint8_t rxChecksum = 0;
uint8_t rxPayload[64];
// Helpers
void debugPrint(const String &s) {
  DBG_SERIAL.println(s);
void sendBinaryPacket(uint8_t cmd, const uint8_t *payload, uint8_t len) {
  uint8_t cs = cmd ^ len;
  LINK_SERIAL.write(UART_HEADER);
  LINK_SERIAL.write(cmd);
  LINK_SERIAL.write(len);
  for (uint8_t i = 0; i < len; i++) {
    LINK_SERIAL.write(payload[i]);
    cs ^= payload[i];
  LINK_SERIAL.write(cs);
void sendAck(const String &msg) {
  uint8_t payload[24];
  uint8_t len = msg.length();
  if (len > 24) len = 24;
  for (uint8_t i = 0; i < len; i++) payload[i] = (uint8_t)msg[i];
  sendBinaryPacket(RSP_ACK, payload, len);
void sendNak(const String &msg) {
  sendBinaryPacket(RSP_NAK, payload, len);
uint16_t readU16LE(const uint8_t *b) {
  return (uint16_t)b[0] | ((uint16_t)b[1] << 8);
uint32_t readU32LE(const uint8_t *b) {
  return (uint32_t)b[0]
    | ((uint32_t)b[1] << 8)
    | ((uint32_t)b[2] << 16)
    | ((uint32_t)b[3] << 24);
void sendStatus() {
  uint8_t payload[2];
  payload[0] = motorsEnabled ? 1 : 0;
  payload[1] = (uint8_t)mode;
  sendBinaryPacket(RSP_STATUS, payload, 2);
void sendNavAck(const char *msg) {
  sendBinaryPacket(RSP_NAV_ACK, (const uint8_t *)msg, strlen(msg));
void sendDesiredBearingIfChanged() {
  if (desiredBearing100 != lastReportedDesiredBearing) {
    uint8_t payload[2];
    payload[0] = desiredBearing100 & 0xFF;
    payload[1] = (desiredBearing100 >> 8) & 0xFF;
    sendBinaryPacket(RSP_DESIRED_BEARING, payload, 2);
    lastReportedDesiredBearing = desiredBearing100;
void reportStepsOnlyOnStop() {
  uint8_t payload[4];
  payload[0] = totalStepsTaken & 0xFF;
  payload[1] = (totalStepsTaken >> 8) & 0xFF;
  payload[2] = (totalStepsTaken >> 16) & 0xFF;
  payload[3] = (totalStepsTaken >> 24) & 0xFF;
  sendBinaryPacket(RSP_TOTAL_STEPS, payload, 4);
  lastReportedStepsOnStop = totalStepsTaken;
void stopMotors() {
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  LeftFrontWheel.runSpeed();
  LeftBackWheel.runSpeed();
  RightFrontWheel.runSpeed();
  RightBackWheel.runSpeed();
void applyMotorSpeeds() {
  LeftFrontWheel.setSpeed(leftCurrentSpeed);
  LeftBackWheel.setSpeed(leftCurrentSpeed);
  RightFrontWheel.setSpeed(rightCurrentSpeed);
  RightBackWheel.setSpeed(rightCurrentSpeed);
void rampTowardTargets() {
  if (leftCurrentSpeed < leftTargetSpeed) {
    leftCurrentSpeed += speedRampStep;
    if (leftCurrentSpeed > leftTargetSpeed) leftCurrentSpeed = leftTargetSpeed;
  } else if (leftCurrentSpeed > leftTargetSpeed) {
    leftCurrentSpeed -= speedRampStep;
    if (leftCurrentSpeed < leftTargetSpeed) leftCurrentSpeed = leftTargetSpeed;
  if (rightCurrentSpeed < rightTargetSpeed) {
    rightCurrentSpeed += speedRampStep;
    if (rightCurrentSpeed > rightTargetSpeed) rightCurrentSpeed = rightTargetSpeed;
  } else if (rightCurrentSpeed > rightTargetSpeed) {
    rightCurrentSpeed -= speedRampStep;
    if (rightCurrentSpeed < rightTargetSpeed) rightCurrentSpeed = rightTargetSpeed;
void setMotionMode(MotionMode newMode) {
  if (mode == newMode) return;
  mode = newMode;
  sendStatus();
void startLeg() {
  legStartSteps = totalStepsTaken;
  nextScanAtSteps = scanIntervalSteps;
  legLoaded = true;
  motorsEnabled = true;
void requestObstacleScan() {
  sendBinaryPacket(RSP_OBS_SCAN_REQUEST, nullptr, 0);
void handleStopEvent(const char *reason) {
  debugPrint(String("STOP: ") + reason);
  stopMotors();
  setMotionMode(MODE_IDLE);
  reportStepsOnlyOnStop();
  sendAck("STOP");
void handleWaypointPacket(const uint8_t *p, uint8_t len) {
  if (len != 22) {
    sendNak("WAYPOINT_LEN");
    return;
  pathTotalDistance = readU32LE(&p[0]);
  combinedStepsDesired = readU32LE(&p[4]);
  oppositeDistance = readU32LE(&p[8]);
  bearingAlignment = p[12];
  desiredBearing100 = readU16LE(&p[13]);
  actualBearing100 = readU16LE(&p[15]);
  trackDir = p[17];
  scanIntervalSteps = readU32LE(&p[18]);
  debugPrint("WAYPOINT received");
  debugPrint("pathTotalDistance=" + String(pathTotalDistance));
  debugPrint("combinedStepsDesired=" + String(combinedStepsDesired));
  debugPrint("oppositeDistance=" + String(oppositeDistance));
  debugPrint("bearingAlignment=" + String(bearingAlignment));
  debugPrint("desiredBearing100=" + String(desiredBearing100));
  debugPrint("actualBearing100=" + String(actualBearing100));
  debugPrint("trackDir=" + String(trackDir));
  debugPrint("scanIntervalSteps=" + String(scanIntervalSteps));
  if (bearingAlignment == 1) {
    // Offset reflector position logic can be refined later
    // For now this just acknowledges that desired bearing can be adjusted locally.
  sendDesiredBearingIfChanged();
  sendNavAck("WAYPOINT");
  setMotionMode(MODE_PIVOT);
  startLeg();
void handleBinaryPacket(uint8_t cmd, const uint8_t *payload, uint8_t len) {
  switch (cmd) {
    case CMD_STOP_MOTORS:
      handleStopEvent("CMD_STOP_MOTORS");
      break;
    case CMD_ACTUAL_BEARING:
      if (len != 2) {
        sendNak("ACTUAL_BEARING_LEN");
        return;
      actualBearing100 = readU16LE(payload);
      sendAck("ACTUAL_BEARING");
      break;
    case CMD_RIGHT_PIVOT:
      if (len != 2) {
        sendNak("RIGHT_PIVOT_LEN");
        return;
      combinedStepsDesired = readU16LE(payload);
      sendAck("RIGHT_PIVOT");
      break;
    case CMD_LEFT_PIVOT:
      if (len != 2) {
        sendNak("LEFT_PIVOT_LEN");
        return;
      sendAck("LEFT_PIVOT");
      break;
    case CMD_WAYPOINT_DATA:
      handleWaypointPacket(payload, len);
      break;
    case CMD_RESUME:
      setMotionMode(resumeMode);
      sendAck("RESUME");
      break;
    case CMD_PAUSE:
      resumeMode = mode;
      setMotionMode(MODE_PAUSED);
      stopMotors();
      sendAck("PAUSE");
      break;
    default:
      sendNak("UNKNOWN_CMD");
      break;
void processIncoming() {
  while (LINK_SERIAL.available() > 0) {
    uint8_t b = (uint8_t)LINK_SERIAL.read();
    switch (rxState) {
      case 0:
        if (b == UART_HEADER) rxState = 1;
        break;
      case 1:
        rxCmd = b;
        rxChecksum = rxCmd;
        rxState = 2;
        break;
      case 2:
        rxLen = b;
        rxChecksum ^= rxLen;
        rxIndex = 0;
        if (rxLen > sizeof(rxPayload)) {
          rxState = 0;
          sendNak("LEN_OVF");
        } else {
          rxState = (rxLen == 0) ? 4 : 3;
        break;
      case 3:
        rxPayload[rxIndex++] = b;
        rxChecksum ^= b;
        if (rxIndex >= rxLen) rxState = 4;
        break;
      case 4:
        if (b == rxChecksum) {
          handleBinaryPacket(rxCmd, rxPayload, rxLen);
        } else {
          sendNak("CS");
        rxState = 0;
        rxCmd = 0;
        rxLen = 0;
        rxIndex = 0;
        rxChecksum = 0;
        break;
void updateMotion() {
  if (!motorsEnabled) {
    stopMotors();
    return;
  uint32_t stepsInLeg = totalStepsTaken - legStartSteps;
  if (mode == MODE_PIVOT) {
    int error = (int)desiredBearing100 - (int)actualBearing100;
    if (error > 25) {
      leftTargetSpeed = wheelSpeedBase;
      rightTargetSpeed = -wheelSpeedBase;
    } else if (error < -25) {
      leftTargetSpeed = -wheelSpeedBase;
      rightTargetSpeed = wheelSpeedBase;
    } else {
      // Pivot complete -> move into track mode
      setMotionMode(MODE_TRACK);
  if (mode == MODE_TRACK) {
    int steer = error / 50;
    if (steer > 400) steer = 400;
    if (steer < -400) steer = -400;
    leftTargetSpeed = wheelSpeedBase + steer;
    rightTargetSpeed = wheelSpeedBase - steer;
    if (leftTargetSpeed > wheelSpeedBase + 400) leftTargetSpeed = wheelSpeedBase + 400;
    if (rightTargetSpeed > wheelSpeedBase + 400) rightTargetSpeed = wheelSpeedBase + 400;
    if (leftTargetSpeed < -wheelSpeedBase) leftTargetSpeed = -wheelSpeedBase;
    if (rightTargetSpeed < -wheelSpeedBase) rightTargetSpeed = -wheelSpeedBase;
    if (!scanPending && scanIntervalSteps > 0 && stepsInLeg >= nextScanAtSteps) {
      scanPending = true;
      requestObstacleScan();
      nextScanAtSteps += scanIntervalSteps;
    if (combinedStepsDesired > 0 && stepsInLeg >= combinedStepsDesired) {
      handleStopEvent("LEG_COMPLETE");
      return;
  if (mode == MODE_PAUSED || mode == MODE_COMPLETE || mode == MODE_IDLE) {
  rampTowardTargets();
  applyMotorSpeeds();
  totalStepsTaken = (uint32_t)(labs(LeftFrontWheel.currentPosition()) + labs(RightFrontWheel.currentPosition()));
void setup() {
  DBG_SERIAL.begin(BAUD);
  LINK_SERIAL.begin(BAUD);
  LeftFrontWheel.setMaxSpeed(wheelSpeedBase * 2);
  LeftBackWheel.setMaxSpeed(wheelSpeedBase * 2);
  RightFrontWheel.setMaxSpeed(wheelSpeedBase * 2);
  RightBackWheel.setMaxSpeed(wheelSpeedBase * 2);
  debugPrint("MEGA_FIRMWARE_v6 started");
  uint8_t payload[] = { 'R', 'E', 'A', 'D', 'Y' };
  sendBinaryPacket(RSP_READY, payload, 5);
  sendStatus();
void loop() {
  processIncoming();
  // Only update bearing announcement when it changes by 1 degree or more.
  updateMotion();
  delay(1);
MEGA_MGR_v7
var UART_INDEX = 0;
var UART_BAUD = 115200;
var UART_HEADER = 0xA5;
var CMD_STOP_MOTORS = 0x01;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_DATA = 0x06;
var CMD_RESUME = 0x07;
var CMD_PAUSE = 0x08;
// Responses from Mega
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
var RSP_READY = 0x14;
var RSP_STATUS = 0x15;
var RSP_ACK = 0x16;
var RSP_NAK = 0x17;
var rxState = 0;
var rxCmd = 0;
var rxLen = 0;
var rxIndex = 0;
var rxPayload = [];
var rxChecksum = 0;
function safeInt(v, def) {
  var n = parseInt(v);
  if (isNaN(n)) return def;
  return n;
function u16ToBytes(value) {
  value = value & 0xFFFF;
  return [value & 0xFF, (value >> 8) & 0xFF];
function u32ToBytes(value) {
  value = value >>> 0;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF,
    (value >> 16) & 0xFF,
    (value >> 24) & 0xFF
function bytesToU16LE(b0, b1) {
  return (b0 & 0xFF) | ((b1 & 0xFF) << 8);
function sendPacket(cmd, payload) {
  var checksum = cmd ^ payload.length;
  UART.hardwareUartWrite(UART_INDEX, [UART_HEADER]);
  UART.hardwareUartWrite(UART_INDEX, [cmd]);
  UART.hardwareUartWrite(UART_INDEX, [payload.length]);
  if (payload.length > 0) {
    UART.hardwareUartWrite(UART_INDEX, payload);
    for (var i = 0; i < payload.length; i++) {
      checksum ^= (payload[i] & 0xFF);
  UART.hardwareUartWrite(UART_INDEX, [checksum & 0xFF]);
function sendStopMotors() {
  sendPacket(CMD_STOP_MOTORS, []);
  print("TX: STOP");
function sendActualBearing() {
  var bearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  bearing100 = Math.max(0, Math.min(18000, bearing100));
  sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
  print("TX: ACTUAL BEARING = " + bearing100);
function sendWaypointData() {
  var pathTotalDistance = safeInt(getVar("$pathTotalDistance", 0), 0) >>> 0;
  var combinedStepsDesired = safeInt(getVar("$combinedStepsDesired", 0), 0) >>> 0;
  var oppositeDistance = safeInt(getVar("$oppositeDistance", 0), 0) >>> 0;
  var bearingAlignment = safeInt(getVar("$bearingAlignment", 0), 0) & 0xFF;
  var trackDir = safeInt(getVar("$trackDir", 0), 0) ? 1 : 0;
  var desiredBearing100 = safeInt(getVar("$desiredBearing100", 9000), 9000);
  var actualBearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  var scanIntervalSteps = safeInt(getVar("$scanIntervalSteps", 3056), 3056) >>> 0;
  var payload = [];
  payload = payload.concat(u32ToBytes(pathTotalDistance));
  payload = payload.concat(u32ToBytes(combinedStepsDesired));
  payload = payload.concat(u32ToBytes(oppositeDistance));
  payload.push(bearingAlignment);
  payload = payload.concat(u16ToBytes(desiredBearing100));
  payload = payload.concat(u16ToBytes(actualBearing100));
  payload.push(trackDir);
  payload = payload.concat(u32ToBytes(scanIntervalSteps));
  if (payload.length !== 22) {
    print("Waypoint payload length error: " + payload.length);
    return;
  setVar("$legComplete", 0);
  setVar("$navAckReceived", 0);
  sendPacket(CMD_WAYPOINT_DATA, payload);
  print("TX: WAYPOINT DATA");
function sendPivot(cmd, name) {
  var steps = safeInt(getVar("$pivotSteps", 0), 0) >>> 0;
  sendPacket(cmd, u16ToBytes(steps));
  print("TX: " + name + " steps=" + steps);
function sendPause() {
  sendPacket(CMD_PAUSE, []);
  print("TX: PAUSE");
function sendResume() {
  sendPacket(CMD_RESUME, []);
  print("TX: RESUME");
function handleRxPacket(cmd, payload) {
  if (cmd == RSP_READY) {
    print("RX: READY");
    setVar("$megaReady", 1);
    return;
  if (cmd == RSP_ACK) {
    print("RX: ACK");
    return;
  if (cmd == RSP_NAK) {
    print("RX: NAK");
    return;
  if (cmd == RSP_NAV_ACK) {
    print("RX: NAV ACK");
    setVar("$navAckReceived", 1);
    return;
  if (cmd == RSP_STATUS) {
    print("RX: STATUS");
    return;
  if (cmd == RSP_DESIRED_BEARING) {
    if (payload.length == 2) {
      var bearing100 = bytesToU16LE(payload[0], payload[1]);
      setVar("$desiredBearing100", bearing100);
      print("RX: DESIRED BEARING x100 = " + bearing100);
    return;
  if (cmd == RSP_OBS_SCAN_REQUEST) {
    setVar("$obsScanRequested", 1);
    print("RX: OBSTACLE SCAN REQUEST");
    return;
  // Ignore step totals unless you explicitly want to display them later.
function processIncomingBytes() {
  var available = UART.hardwareUartAvailable(UART_INDEX);
  while (available > 0) {
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0] & 0xFF;
    available--;
    if (rxState == 0) {
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxChecksum = rxCmd;
      rxState = 2;
      continue;
    if (rxState == 2) {
      rxLen = b;
      rxPayload = [];
      rxIndex = 0;
      continue;
    if (rxState == 3) {
      rxPayload.push(b);
      rxChecksum ^= b;
      rxIndex++;
      continue;
    if (rxState == 4) {
      var cs = b & 0xFF;
      if (cs == (rxChecksum & 0xFF)) {
        handleRxPacket(rxCmd, rxPayload);
      } else {
        print("RX checksum error. cmd=" + rxCmd + " expected=" + (rxChecksum & 0xFF) + " got=" + cs);
      rxState = 0;
      rxCmd = 0;
      rxLen = 0;
      rxIndex = 0;
      rxPayload = [];
      rxChecksum = 0;
      continue;
print("MEGA_MGR_v7 started");
UART.initHardwareUart(UART_INDEX, UART_BAUD);
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1) {
    sendWaypointData();
    setVar("$sendWaypointNow", 0);
  if (getVar("$sendStopNow", 0) == 1) {
    sendStopMotors();
    setVar("$sendStopNow", 0);
  if (getVar("$sendPauseNow", 0) == 1) {
    sendPause();
    setVar("$sendPauseNow", 0);
  if (getVar("$sendResumeNow", 0) == 1) {
    sendResume();
    setVar("$sendResumeNow", 0);
  if (getVar("$sendActualBearingNow", 0) == 1) {
    sendActualBearing();
    setVar("$sendActualBearingNow", 0);
  if (getVar("$sendRightPivotNow", 0) == 1) {
    sendPivot(CMD_RIGHT_PIVOT, "RIGHT PIVOT");
    setVar("$sendRightPivotNow", 0);
  if (getVar("$sendLeftPivotNow", 0) == 1) {
    sendPivot(CMD_LEFT_PIVOT, "LEFT PIVOT");
    setVar("$sendLeftPivotNow", 0);
  processIncomingBytes();
  sleep(20);
TEENSY_FIRMWARE_v4 and PacketHandler
//PacketHandler.h
#pragma once
#include <Arduino.h>
struct PacketResult {
  bool valid;
  String payload;
uint8_t simpleChecksum(const String& payload);
String toHex2(uint8_t value);
PacketResult parsePacket(const String& packet);
String buildPacket(const String& payload);
PacketHandler.cpp
#include "PacketHandler.h"
uint8_t simpleChecksum(const String& payload) {
  uint8_t sum = 0;
  for (size_t i = 0; i < payload.length(); i++) {
    sum ^= (uint8_t)payload.charAt(i);
  return sum;
String toHex2(uint8_t value) {
  const char hex[] = "0123456789ABCDEF";
  String out;
  out += hex[(value >> 4) & 0x0F];
  out += hex[value & 0x0F];
  return out;
PacketResult parsePacket(const String& packet) {
  PacketResult result;
  result.valid = false;
  result.payload = "";
  if (packet.length() < 5) return result;
  if (packet.charAt(0) != '$') return result;
  int star = packet.indexOf('*');
  if (star < 0) return result;
  if (star + 2 >= packet.length()) return result;
  String payload = packet.substring(1, star);
  String checksumText = packet.substring(star + 1, star + 3);
  uint8_t received = (uint8_t)strtol(checksumText.c_str(), nullptr, 16);
  uint8_t computed = simpleChecksum(payload);
  if (received != computed) return result;
  result.valid = true;
  result.payload = payload;
  return result;
String buildPacket(const String& payload) {
  uint8_t chk = simpleChecksum(payload);
  return "$" + payload + "*" + toHex2(chk) + "\n";
IR_TRACKER_v4.h
#pragma once
#include <Servo.h>
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
static const uint8_t SERVO_PIN = 29;
static const uint8_t IR_PIN = A14;
static const int SERVO_MIN_ANGLE = 5;
static const int SERVO_MAX_ANGLE = 175;
static const int SERVO_MIN_PULSE = 500;
static const int SERVO_MAX_PULSE = 2500;
static const int DESIRED_BEARING = 90;
static const int STEP_DELTA = 1;
static const int RUNAWAY_MARGIN = 20;
static const int RESET_DELAY_MS = 20;
static const int SETTLE_DELAY_MS = 30;
static const int IR_THRESHOLD = 15;
static const int IR_SMOOTH_SAMPLES = 8;
static const int ADC_MAX_RAW = 4095;
static const long NEG_OBS_MAX = 2000;
static const long POS_OBS_MAX = 2000;
static const unsigned long EZB_BAUD = 115200;
extern servo trackingServo;
extern TrackerState state;
extern int desiredBearing;
extern int roundedBearing;
extern int actualBearing;
extern int bearing;
extern int negInit;
extern int negFinal;
extern int posInit;
extern int posFinal;
extern long negObsTot;
extern long posObsTot;
extern int bearingCount;
extern int runawayCount;
extern int negAbortLimit;
extern int posAbortLimit;
extern bool stopRequested;
extern bool startRequested;
void setupTracker();
void loopTracker();
void beginNegSweep();
void beginPosSweep();
void doNegSearchInit();
void doNegSearchFinal();
void doPosSearchInit();
void doPosSearchFinal();
void stopNow(const char* reason);
void processTrackerState();
int normalizeIRTo255(int raw);
int readIRSmooth();
int clampServoAngle(int angle);
void setServoBearing(int angle);
int readServo();
void publishBearing(int candidate);
void updateBearingFromInitEdges();
void updateBearingFromFinalEdges();
void handleRunaway();
void pollSerial();
void handleSerialCommand(const String& cmd);
void sendToEZB(const String& msg);
void sendBearingUpdate();
void sendBearingCount();
void sendStatus();
void sendAck(const String& cmd);
void sendNak(const String& reason);
IR_TRACKER_v4.cpp
#include "IR_TRACKER_v4.h"
Servo trackingServo;
TrackerState state = NEG_SEARCH_INIT;
int desiredBearing = DESIRED_BEARING;
int roundedBearing = DESIRED_BEARING;
int actualBearing = DESIRED_BEARING;
int bearing = DESIRED_BEARING;
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
int bearingCount = 0;
int runawayCount = 0;
int negAbortLimit = 0;
int posAbortLimit = 0;
bool stopRequested = false;
bool startRequested = false;
static int irSamples[IR_SMOOTH_SAMPLES];
static int irSampleIndex = 0;
static bool irInitialized = false;
static unsigned long lastDebugMs = 0;
static int lastActualBearing = -1;
static int lastPublishedBearing = -1;
static int prevLastPublishedBearing = -1;
static String serialPacket;
static bool inPacket = false;
static unsigned long packetStartMs = 0;
static bool teensyReady = false;
static int clampAngle(int angle) {
  return constrain(angle, SERVO_MIN_ANGLE, SERVO_MAX_ANGLE);
int clampServoAngle(int angle) {
  return clampAngle(angle);
void setServoBearing(int angle) {
  bearing = clampAngle(angle);
  trackingServo.write(bearing);
int readServo() {
  return bearing;
int normalizeIRTo255(int raw) {
  raw = constrain(raw, 0, ADC_MAX_RAW);
  return map(raw, 0, ADC_MAX_RAW, 0, 255);
int readIRSmooth() {
  int raw = analogRead(IR_PIN);
  if (!irInitialized) {
    for (int i = 0; i < IR_SMOOTH_SAMPLES; i++) {
      irSamples[i] = raw;
    irInitialized = true;
  } else {
    irSamples[irSampleIndex] = raw;
    irSampleIndex = (irSampleIndex + 1) % IR_SMOOTH_SAMPLES;
  long sum = 0;
    sum += irSamples[i];
  return (int)(sum / IR_SMOOTH_SAMPLES);
void sendToEZB(const String& msg) {
  Serial8.print(buildPacket(msg));
void sendAck(const String& cmd) {
  sendToEZB("ACK," + cmd);
void sendNak(const String& reason) {
  sendToEZB("NAK," + reason);
void sendBearingUpdate() {
  sendToEZB("BEARING," + String(actualBearing));
void sendBearingCount() {
  sendToEZB("COUNT," + String(bearingCount));
void sendStatus() {
  String msg = "STATUS,STATE=" + String((int)state);
  msg += ",BEARING=" + String(bearing);
  msg += ",ACTUAL=" + String(actualBearing);
  msg += ",COUNT=" + String(bearingCount);
  msg += ",RUNAWAY=" + String(runawayCount);
  msg += ",READY=" + String(teensyReady ? 1 : 0);
  sendToEZB(msg);
void publishBearing(int candidate) {
  roundedBearing = candidate;
  if (roundedBearing == lastActualBearing) {
    if (roundedBearing != lastPublishedBearing && roundedBearing != prevLastPublishedBearing) {
      prevLastPublishedBearing = lastPublishedBearing;
      lastPublishedBearing = roundedBearing;
      actualBearing = roundedBearing;
  } else {
    lastActualBearing = roundedBearing;
void updateBearingFromInitEdges() {
  if (negInit >= 0 && posInit >= 0) {
    int candidate = (negInit + posInit) / 2;
    bearingCount++;
    publishBearing(candidate);
void updateBearingFromFinalEdges() {
  if (negFinal >= 0 && posFinal >= 0) {
    int candidate = (negFinal + posFinal) / 2;
    bearingCount++;
void stopNow(const char* reason) {
  Serial.print("STOP: ");
  Serial.println(reason);
  setServoBearing(roundedBearing);
  delay(RESET_DELAY_MS);
  sendToEZB("STOP");
  sendBearingCount();
  stopRequested = true;
  state = TRACKER_STOPPED;
void beginNegSweep() {
  delay(SETTLE_DELAY_MS);
  if (negObsTot > NEG_OBS_MAX) {
    stopNow("NEG OBS total exceeded max");
    return;
  if (posObsTot > POS_OBS_MAX) {
    stopNow("POS OBS total exceeded max");
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  negAbortLimit = roundedBearing - RUNAWAY_MARGIN;
void beginPosSweep() {
  posInit = -1;
  posFinal = -1;
  posAbortLimit = roundedBearing + RUNAWAY_MARGIN;
  state = POS_SEARCH_INIT;
void handleRunaway() {
  runawayCount++;
  if (runawayCount >= 3) {
    stopNow("Runaway limit reached");
    return;
  if (state == NEG_SEARCH_INIT) {
    beginPosSweep();
  } else {
    beginNegSweep();
void doNegSearchInit() {
  int current = readServo();
  int irNorm = normalizeIRTo255(readIRSmooth());
  bool reflectorDetected = (irNorm >= IR_THRESHOLD);
  if (current < negAbortLimit) {
    handleRunaway();
    return;
  if (reflectorDetected) {
    negInit = current;
    state = NEG_SEARCH_FINAL;
  } else {
    int next = current - STEP_DELTA;
    setServoBearing(next);
void doNegSearchFinal() {
    handleRunaway();
    return;
    negFinal = current;
  } else {
void doPosSearchInit() {
  if (current > posAbortLimit) {
    handleRunaway();
    return;
    posInit = current;
    state = POS_SEARCH_FINAL;
  } else {
    int next = current + STEP_DELTA;
void doPosSearchFinal() {
    handleRunaway();
    return;
    posFinal = current;
  } else {
void handleSerialCommand(const String& cmd) {
  String s = cmd;
  s.trim();
  s.toUpperCase();
  if (s == "HELLO") {
    teensyReady = true;
    sendToEZB("READY,IR_TRACKERv4.2.1");
    sendAck("HELLO");
    return;
  if (s == "START") {
    startRequested = true;
    sendAck("START");
    return;
  if (s == "STOP") {
    stopNow("Serial STOP");
    sendAck("STOP");
    return;
  if (s == "STATUS?") {
    sendStatus();
    sendAck("STATUS?");
    return;
  if (s.startsWith("BEARING,")) {
    int value = s.substring(8).toInt();
    roundedBearing = clampServoAngle(value);
    sendAck("BEARING");
    return;
  if (s.startsWith("COUNT,")) {
    int value = s.substring(6).toInt();
    bearingCount = value;
    sendAck("COUNT");
    return;
void pollSerial() {
  while (Serial8.available() > 0) {
    char c = (char)Serial8.read();
    if (!inPacket) {
      if (c == '$') {
        inPacket = true;
        serialPacket = "$";
        packetStartMs = millis();
      continue;
    if (millis() - packetStartMs > 250) {
      inPacket = false;
      serialPacket = "";
      sendNak("TIMEOUT");
      continue;
    serialPacket += c;
    if (serialPacket.length() > 128) {
      inPacket = false;
      serialPacket = "";
      sendNak("OVERFLOW");
      continue;
    if (c == '\n') {
      PacketResult result = parsePacket(serialPacket);
      if (result.valid) {
        handleSerialCommand(result.payload);
      } else {
        sendNak("BAD_CRC");
      serialPacket = "";
      inPacket = false;
void processTrackerState() {
  if (stopRequested || !startRequested) return;
  switch (state) {
    case NEG_SEARCH_INIT: doNegSearchInit(); break;
    case NEG_SEARCH_FINAL: doNegSearchFinal(); break;
    case POS_SEARCH_INIT: doPosSearchInit(); break;
    case POS_SEARCH_FINAL: doPosSearchFinal(); break;
    case TRACKER_STOPPED:
    default:
      return;
  if (millis() - lastDebugMs >= 1000) {
    lastDebugMs = millis();
    Serial.print("state=");
    Serial.print((int)state);
    Serial.print(" bearing=");
    Serial.print(bearing);
    Serial.print(" actualBearing=");
    Serial.print(actualBearing);
    Serial.print(" count=");
    Serial.print(bearingCount);
    Serial.print(" ready=");
    Serial.println(teensyReady ? 1 : 0);
void setupTracker() {
  Serial.begin(EZB_BAUD);
  Serial8.begin(EZB_BAUD);
  delay(1000);
  analogReadResolution(12);
  pinMode(IR_PIN, INPUT);
  trackingServo.attach(SERVO_PIN, SERVO_MIN_PULSE, SERVO_MAX_PULSE);
  Serial.println("IR_TRACKERv4.2.1 READY");
void loopTracker() {
  pollSerial();
TEENSY_MGR_v2
var running = true;
function checksumXor(payload) {
  var sum = 0;
    sum = sum ^ payload.charCodeAt(i);
  return sum & 0xFF;
function toHex2(value) {
  var hex = "0123456789ABCDEF";
  return hex.charAt((value >> 4) & 0x0F) + hex.charAt(value & 0x0F);
function buildPacket(payload) {
  var chk = checksumXor(payload);
function sendPacket(payload) {
  var packet = buildPacket(payload);
  print("TX: " + packet.trim());
  // Replace this with the actual ARC command you use to write to the EZ-B UART.
  // If you are using a UART robot skill, send through its   ControlCommand API.
  // Example pattern only:
  // controlCommand("UART", "WriteString", packet);
function handleLine(line) {
  line = line.trim();
  if (line.length == 0) return;
  print("RX: " + line);
  if (line.charAt(0) != '$') return;
  var star = line.indexOf('*');
  if (star < 0) return;
  var payload = line.substring(1, star);
  var parts = payload.split(",");
  if (parts[0] == "READY") {
    print("Teensy ready: " + payload);
  } else if (parts[0] == "ACK") {
    print("ACK for " + parts[1]);
  } else if (parts[0] == "NAK") {
    print("NAK reason: " + parts[1]);
  } else if (parts[0] == "STATUS") {
    print("Status: " + payload);
  } else if (parts[0] == "BEARING") {
    print("Bearing: " + parts[1]);
  } else if (parts[0] == "COUNT") {
    print("Count: " + parts[1]);
  } else if (parts[0] == "STOP") {
    print("Teensy stopped");
    running = false;
function pollTeensy() {
  // Replace this with the ARC read method for the UART   robot skill or EZ-B serial device.
  // while (UART.available() > 0) {
  //   var line = UART.readLine();
  //   handleLine(line);
sleep(1000);
sendPacket("HELLO");
sendPacket("STATUS?");
sendPacket("START");
while (running) {
  pollTeensy();
  sleep(50);
USB
Digital 21
Script by Synthiam
Python Native by Synthiam Inc.
Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control.
Thanks - there are a couple of very likely failure points in this architecture, and both problems point to ARC UART routing / packet framing / skill wiring, not just firmware logic.
First, the biggest issue I see
Your Teensy manager is not actually sending anything to the UART yet.
In TEENSY_MGR_v2 you have:
That means:
  • it prints the packet
  • but it does not write to the EZ-B UART
  • so the Mega never receives the bearing updates unless you’ve implemented that missing write elsewhere
That alone explains Problem #2.
Problem #1: Why RSP_TOTAL_STEPS is not observed by MEGA_MGR_v7
The most likely causes
1) The Mega firmware may be sending the packet, but MEGA_MGR_v7 is not reading it at the right time
Your ARC JavaScript loop does:
while (true) {
  sleep(20);
That part is fine, but the Mega firmware may only send RSP_TOTAL_STEPS inside handleStopEvent(), and your posted firmware snippet does not include that function or the stop path itself.
So the first thing to verify is:
  • Is handleStopEvent() actually calling reportStepsOnlyOnStop()?
  • Is it calling sendBinaryPacket(RSP_TOTAL_STEPS, ...) before the serial buffer gets reset or the task exits?
  • Is the stop coming from ARC, or from the Mega itself?
2) Your ARC parser may be ignoring RSP_TOTAL_STEPS
In MEGA_MGR_v7:
if (cmd == RSP_OBS_SCAN_REQUEST) { ... return; }
So even if the Mega sends RSP_TOTAL_STEPS, your manager currently appears to discard it silently.
That means:
  • the packet may actually be arriving
  • but you’ve told ARC to ignore it
If you want to verify it, add:
if (cmd == RSP_TOTAL_STEPS) {
  var steps = bytesToU32LE(payload[0], payload[1], payload[2], payload[3]);
  print("RX: TOTAL STEPS = " + steps);
  setVar("$totalStepsTaken", steps);
  return;
And add a helper:
function bytesToU32LE(b0, b1, b2, b3) {
  return ((b0 & 0xFF)) |
    ((b1 & 0xFF) << 8) |
    ((b2 & 0xFF) << 16) |
    ((b3 & 0xFF) << 24);
3) The Mega stop packet may be malformed
Your binary packet format is:
header (0xA5)
cmd
len
payload...
checksum = XOR of cmd/len/payload
That’s fine, but if sendBinaryPacket() is called with stale or incomplete data, ARC will reject it.
Your ARC code expects:
  • exact header 0xA5
  • valid checksum
  • complete byte stream
I would add debug prints on the Mega before sending:
    cs ^= payload[i];
  DBG_SERIAL.print("TX BIN cmd=0x");
  DBG_SERIAL.print(cmd, HEX);
  DBG_SERIAL.print(" len=");
  DBG_SERIAL.print(len);
  DBG_SERIAL.print(" cs=0x");
  DBG_SERIAL.println(cs, HEX);
This will confirm whether the Mega is even transmitting the packet.
Very important Mega-side concern
Your snippet suggests reportStepsOnlyOnStop() is implemented, but I do not see a guaranteed call to it in the stop path you posted.
You need to confirm stop flow such as:
void handleStopEvent(const char* reason) {
  if (stopJustOccurred) return;
  stopJustOccurred = true;
  stopMotors();
  sendStatus();
  mode = MODE_COMPLETE;
If stop events can happen more than once, the stop guard also matters. Otherwise you may send one packet and immediately overwrite state or suppress it.
Problem #2: Teensy bearing updates not reaching the Mega
The main issue
Your Teensy manager currently only prints received lines and has placeholder comments where UART writes should happen.
So the forward path:
Teensy firmware TEENSY_MGR_v2 Mega firmware / MEGA_MGR_v7
is incomplete.
Also: the serial topology looks wrong conceptually
You said:
  • ARC connects to EZ-B v4
  • Mega and Teensy are connected to the EZ-B via UART(s)
That means ARC has to explicitly:
  1. read from the Teensy UART skill
  2. parse the bearing update
  3. write the bearing update to the Mega UART skill
ARC will not automatically bridge the two UART skills together.
So if TEENSY_MGR_v2 is receiving a packet, it must actively forward it to the Mega through a UART write command.
Option A: Forward inside ARC JavaScript
When TEENSY_MGR_v2 receives:
$BEARING,123*CS
it should call a function that writes to the Mega UART skill.
If the skill exposes UART through ARC control commands, use that.
If not, create a custom robot skill to act as the bridge, which is exactly what ARC is good at:
  • parse Teensy packet
  • transform to Mega packet
  • write to Mega UART
Option B: Let ARC manage both controllers directly
This is often cleaner:
  • Teensy manager reads ASCII from Teensy
  • Mega manager reads/writes binary to Mega
  • a shared ARC script or skill passes data between them using controlCommand()
For example, when Teensy manager parses bearing:
setVar("$actualBearing100", bearing100);
controlCommand("MEGA_MGR_v7", "SendActualBearing", bearing100);
Then MEGA_MGR_v7 would need a custom command handler.
Two specific code issues I noticed in the posted snippets
1) sendActualBearing() is missing from MEGA_MGR_v7
Your loop references:
But the function definition isn’t shown.
If this function is incomplete or broken, your bridge may never transmit bearing data to the Mega.
2) Your TEENSY_MGR_v2 packet example doesn’t match the Teensy firmware packet format
Your Teensy firmware uses:
"$PAYLOAD*CHK\n"
But your handleLine() and sendPacket() need to actually write to the UART and not just print.
Also, in ARC, if you’re using a UART Robot Skill, the write method depends on the actual skill implementation. If you want, I can help you convert this into a clean ARC JavaScript bridge.
What I would do next
Step 1: Confirm the Mega is transmitting
On the Mega, add debug output right before sending RSP_TOTAL_STEPS.
Step 2: Confirm ARC is receiving it
In MEGA_MGR_v7, temporarily log every packet:
print("RX cmd=" + cmd + " len=" + payload.length);
and specifically handle RSP_TOTAL_STEPS.
Step 3: Implement Teensy forwarding
Make TEENSY_MGR_v2 actually write to its UART, then on parsed bearing do:
  • update a variable
  • forward to Mega manager
  • print confirmation
Step 4: Verify the ARC skill wiring
Make sure:
  • the Mega UART skill and Teensy UART skill are on the correct UART indexes
  • the correct EZ-B connection index is used
  • both skills are pointing to the intended controller ports
Helpful ARC references
My diagnosis in one sentence
  • Problem #1: RSP_TOTAL_STEPS is likely either not being emitted in the stop path or is being ignored by MEGA_MGR_v7
  • Problem #2: Teensy bearing updates are not reaching the Mega because TEENSY_MGR_v2 currently does not actually write the packet to the UART
If you want, I can help you do either of these next:
  1. Patch MEGA_MGR_v7 so it logs and forwards RSP_TOTAL_STEPS properly, or
  2. Rewrite TEENSY_MGR_v2 into a working ARC JavaScript bridge that forwards bearing updates to the Mega.
If you paste the missing handleStopEvent() and sendActualBearing() functions, I can pinpoint the exact break.
Hi @Athena. Thank you for your diagnosis. I think it is time to step back and take a fresh look at an earlier starting point when things were clearer to me. I have posted a script from a robot skill called IR _TRACKER_28.
Request:
  1. Can you translate this into C++, so that it will run on a Teensy 4.1?
Thank you. Jack
// REV 28
// Active-low IR reflector tracker
// Tightened four-state flow with reduced duplicate motion logic
// -------------------- CONFIG --------------------
var servoPort = d17;
var irPort = ADC2;
var desiredBearing = 90;
var roundedBearing = 90;
var actualBearing = 90;
var lastActualBearing = -1;
var lastPublishedBearing = -1;
var prevLastPublishedBearing = -1;
var negInit = -1;
var negFinal = -1;
var posInit = -1;
var posFinal = -1;
var negObsTot = 0;
var posObsTot = 0;
var negObsMax = 2000;
var posObsMax = 2000;
var bearingCount = 0;
var reflectorThreshold = 15; // active-low reflector detect: irValue <= threshold
var stepDelta = 1;
var resetDelayMs = 20;
var settleDelayMs = 30;
var runawayCount = 0;
var runawayMargin = 20;
var negAbortLimit = roundedBearing - runawayMargin;
var posAbortLimit = roundedBearing + runawayMargin;
var state = "NEG_SEARCH_INIT";
var stopRequested = false;
setVar("$desiredBearing", desiredBearing);
setVar("$actualBearing", actualBearing);
setVar("$bearingCount", bearingCount);
setVar("$negIRTot", negObsTot);
setVar("$posIRTot", posObsTot);
print("IR tracker Rev28 started.");
// -------------------- HELPERS --------------------
function readIR() {
  return ADC.get(irPort, 0);
function readServo() {
  return Servo.getPosition(servoPort, 0);
function publishBearing(newBearing) {
  roundedBearing = Math.round(newBearing);
  //This second instance allows considering it for a published actual bearing
  //First test: Was it the last published actual bearing?
  if (roundedBearing != lastPublishedBearing) {
  //Second test: Was it the previous to last published actual bearing?
  if (roundedBearing != prevLastPublishedBearing) {
  //It then becomes the global actual bearing
  print("                                   actualBearing:  " + actualBearing);
  }else {// The first instance before considering it for a published actual bearing
function updateBearingFromInitEdges() {
 var candidate = -1;
  // print("negInit:  " + negInit + "    posInit:  " + posInit);
  //print("candidate:  " + candidate);
  if (candidate >= 0) {
    bearingCount++;
  //  print("bearingCount:  " + bearingCount);
function updateBearingFromFinalEdges() {
  var candidate = -1;
   // print(" negFinal:  " + negFinal + "    posFinal:  " + posFinal);
   //print(" candidate:  " + candidate);
    bearingCount++;
function stopNow(reason) {
  print("STOP: " + reason);
  settleDelayMs;
  Servo.setPosition(servoPort, roundedBearing);
  sleep(resetDelayMs);
  setVar("$sendStopNow", 1);
function beginNegSweep() {
  settleDelayMs;
  //print("RESservo:  " + Servo.getPosition(servoPort,0));
  negInit = -1;
  negFinal = -1;
  negObsTot = 0;
function beginPosSweep() {
  settleDelayMs;
// print("RES--servo:  " + Servo.getPosition(servoPort,0));
  posInit = -1;
  posFinal = -1;
  posObsTot = 0;
  state = "POS_SEARCH_INIT";
function handleRunaway() {
  runawayCount++;
  print("runawayCount:  " + runawayCount);
  settleDelayMs;
 if (state == "NEG_SEARCH_INIT" ) {
    beginPosSweep();
    print("POS SWEEP");
  } else {
    beginNegSweep();
    print("NEG SWEEP");
    stopNow("Runaway limit reached: " + runawayCount);
    return;
// -------------------- STATE HANDLERS --------------------
// NEG_SEARCH_INIT
function doNegSearchInit() {
  var current = readServo();
  var irValue = readIR();
  var reflectorDetected = (irValue <= reflectorThreshold);
  negObsTot += irValue;
    handleRunaway();
    return;
  //print("servo( NEG In ):  " + Servo.getPosition(servoPort,0) + "    irValue:  " + irValue);
    negInit = current;
  //print("negInit:  " + negInit);
    runawayCount = 0;
    state = "NEG_SEARCH_FINAL";
  } else {
    Servo.setPosition(servoPort, current - stepDelta);
    settleDelayMs;
// NEG_SEARCH_FINAL
function doNegSearchFinal() {
   //print("servo( NEG Fi ):  " + Servo.getPosition(servoPort,0) + "    irValue:  " + irValue);
  if (!reflectorDetected) {
    negFinal = current;
   //print("negFinal:  " + negFinal);
    beginPosSweep();
  } else {
    settleDelayMs;
// POS_SEARCH_INIT
function doPosSearchInit() {
  posObsTot += irValue;
    handleRunaway();
    return;
//print("servo( POS In ):  " + Servo.getPosition(servoPort,0)+ "    irValue:  " + irValue);
    posInit = current;
   //print("posInit:  " + posInit);
    runawayCount = 0;
    state = "POS_SEARCH_FINAL";
  } else {
    Servo.setPosition(servoPort, current + stepDelta);
    settleDelayMs;
// POS_SEARCH_FINAL
function doPosSearchFinal() {
  //print("servo( POS Fi ):  " + Servo.getPosition(servoPort,0)+ "    irValue:  " + irValue);
    posFinal = current;
   //print("posFinal:  " + posFinal);
    if (negObsTot > negObsMax) {
      stopNow("NEG OBS total exceeded max: " + negObsTot);
      return;
    if (posObsTot > posObsMax) {
    stopNow("POS OBS total exceeded max: " + posObsTot);
    return;
    negObsTot = 0;
    posObsTot = 0;
    beginNegSweep();
  } else {
    settleDelayMs;
// -------------------- MAIN LOOP --------------------
beginNegSweep();
settleDelayMs;
while (true) {
  if (stopRequested) {
    break;
  if (state == "NEG_SEARCH_INIT") {
    doNegSearchInit();
  } else if (state == "NEG_SEARCH_FINAL") {
    doNegSearchFinal();
  } else if (state == "POS_SEARCH_INIT") {
    doPosSearchInit();
  } else if (state == "POS_SEARCH_FINAL") {
    doPosSearchFinal();
 sleep(5);
Absolutely, Jack - and yes, this is a better place to restart.
The script you posted is really a state machine for an IR reflector tracker, so the correct translation to Teensy 4.1 is Arduino C++, not ARC JavaScript. That will give you:
  • deterministic timing
  • direct ADC and servo control
  • cleaner debugging
  • less dependency on ARC scripting behavior
Important note before the translation
Your pasted JavaScript is incomplete / corrupted in a few places:
  • publishBearing(candidate); is referenced but not shown
  • readServo() and readIR() are referenced but not shown
  • several lines appear truncated, such as:
    • var reflectorDetected = (irValue ...
    • if (irValue ...
  • settleDelayMs; appears where you likely meant sleep(settleDelayMs);
So I can translate the intended behavior into C++, but I have to make a few assumptions.
Teensy 4.1 C++ translation
This version assumes:
  • servo on pin 29
  • IR sensor on A14
  • active-low reflector detection
  • servo angle range 5 to 175
  • bearing published over Serial8 in a simple ASCII format
#include <Servo.h>
static const int IR_THRESHOLD = 15;     // active-low detect
// -------------------- STATE --------------------
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
  if (angle < SERVO_MIN_ANGLE) return SERVO_MIN_ANGLE;
  if (angle > SERVO_MAX_ANGLE) return SERVO_MAX_ANGLE;
  return angle;
int readServo() {
  return bearing;
      irSamples[i] = raw;
  long sum = 0;
void sendToEZB(const String &msg) {
  Serial8.println(msg);
void sendAck(const String &cmd) {
void sendNak(const String &reason) {
void sendStatus() {
  String s = "STATUS,";
  s += "state=" + String((int)state);
  s += ",bearing=" + String(bearing);
  s += ",actualBearing=" + String(actualBearing);
  s += ",count=" + String(bearingCount);
  s += ",ready=" + String(teensyReady ? 1 : 0);
  sendToEZB(s);
  actualBearing = clampAngle(candidate);
  sendToEZB("STOP");
  sendBearingCount();
  int candidate = -1;
    bearingCount++;
  int candidate = -1;
    bearingCount++;
  negInit = -1;
  negFinal = -1;
  negObsTot = 0;
  posInit = -1;
  posFinal = -1;
  posObsTot = 0;
  runawayCount++;
  Serial.print("runawayCount: ");
  Serial.println(runawayCount);
    return;
  if (state == NEG_SEARCH_INIT || state == NEG_SEARCH_FINAL) {
    beginPosSweep();
    Serial.println("POS SWEEP");
  } else {
    beginNegSweep();
    Serial.println("NEG SWEEP");
  int irValue = normalizeIRTo255(readIRSmooth());
  bool reflectorDetected = (irValue <= IR_THRESHOLD);
    handleRunaway();
    return;
    negInit = current;
    runawayCount = 0;
  } else {
    setServoBearing(current - STEP_DELTA);
    handleRunaway();
    return;
    negFinal = current;
  } else {
    handleRunaway();
    return;
    posInit = current;
    runawayCount = 0;
  } else {
    setServoBearing(current + STEP_DELTA);
    handleRunaway();
    return;
    posFinal = current;
  } else {
// -------------------- SERIAL PROTOCOL --------------------
void handleSerialCommand(const String &cmd) {
  String s = cmd;
  s.trim();
  s.toUpperCase();
  if (s == "HELLO") {
    teensyReady = true;
    sendToEZB("READY,IR_TRACKERv28");
    sendAck("HELLO");
    return;
  if (s == "START") {
    sendAck("START");
    return;
  if (s == "STOP") {
    sendAck("STOP");
    return;
    sendStatus();
    sendAck("STATUS?");
    return;
    roundedBearing = clampAngle(value);
    sendAck("BEARING");
    return;
    sendAck("COUNT");
    return;
void pollSerial() {
    if (!inPacket) {
      if (c == '$') {
        inPacket = true;
        serialPacket = "$";
      continue;
      inPacket = false;
      serialPacket = "";
      sendNak("TIMEOUT");
      continue;
    serialPacket += c;
      inPacket = false;
      serialPacket = "";
      continue;
    if (c == '\n') {
      // Simple packet format assumed here:
      // $PAYLOAD*CHK\n
      int star = serialPacket.indexOf('*');
      if (star > 0 && star + 3 <= serialPacket.length()) {
        String payload = serialPacket.substring(1, star);
        String checksumText = serialPacket.substring(star + 1, star + 3);
        uint8_t computed = 0;
          computed ^= (uint8_t)payload[i];
        if (received == computed) {
          handleSerialCommand(payload);
        } else {
          sendNak("BAD_CRC");
      } else {
        sendNak("BAD_FMT");
      serialPacket = "";
      inPacket = false;
  switch (state) {
    default: return;
// -------------------- ARDUINO --------------------
void setup() {
  Serial.begin(115200);
  Serial8.begin(115200);
  trackingServo.attach(SERVO_PIN);
  Serial.println("IR_TRACKERv28 READY");
void loop() {
  pollSerial();
What this translation is doing
It preserves the core behavior of your ARC script:
  • sweeps the servo left/right
  • reads the IR sensor
  • detects reflector edges
  • computes bearing from paired edge detections
  • handles runaway conditions
  • sends:
    • READY
    • STOP
    • COUNT
    • BEARING,<value>
    • ACK / NAK
Important correction
Your original ARC script appears to use servo position as bearing. That works, but in C++ you should be clear whether:
  • bearing means servo angle
  • actualBearing means computed reflector bearing
  • roundedBearing means the current center point
That separation matters because otherwise the tracker gets hard to debug.
Better ARC/Teensy architecture
Since you’re moving this to Teensy 4.1, the cleanest pattern is:
  1. Teensy runs the tracker in C++
  2. Teensy sends a small ASCII status packet to ARC
  3. ARC only acts as the UI / coordinator
That is much better than trying to keep the full tracker logic split across ARC JavaScript and firmware.
A couple of questions so I can make this exact
  1. What exact servo hardware are you using on the Teensy 4.1?
    Standard PWM servo, or a smart servo?
  2. Do you want the Teensy to talk to ARC using the same ASCII packet format you already started with, or should I convert this to a binary protocol?
  3. What is the ultimate goal of the tracker?
    Is it just to find a reflector and report bearing, or should it also directly drive the Mega navigation logic?
If you want, I can do the next step and give you a full Teensy 4.1 project split into .h / .cpp files that is ready to paste into Arduino IDE.
@Athena. Thank you for the translation into Arduino C++. After reviewing the translation, I have some concerns:
  1. First, it appears that most times a block of code is submitted something happens in the process, and it does not accurately reproduce on your end. This is a problem because any meaningful communication is thwarted and assumptions are made as to the real meaning of the code. I'm not sure what the solution is, do you have any suggestions on how to stop code blocks changing after being submitted?
  2. The JavaScript code submitted for translation was accurate copy provided by you several posts back. I checked it for accuracy as the code that I wanted to be translated into Arduino C++. Review the JavaScript posted above and compare it to the Arduino C++ translation. The translation in Arduino C++ is very dissimilar to the JavaScript code I submitted. For instance, examine the following functions in JavaScript and compare to their counterpart in Arduino C++.
  • JavaScript: function doNegSearchFinal() compare to Arduino C++: void doNegSearchFinal()
  • JavaScript: function doPosSearchFinal() compare to ArduinoC++: void doPosSearchFinal()
Request:
  1. Can you translate the JavaScript code of last post, IR\_TRACKER\_v28 into Arduino C++, paying particular attention to the above functions noted above? Thank you for your continued support. Jack
Yes - and you’re right to call that out.
1) About the code changing after submission
What you’re seeing is usually one of these issues:
  • Forum/markup corruption: characters like <, >, &, quotes, and apostrophes can be altered when pasted into rich text or forum editors.
  • Truncation: long code blocks sometimes get clipped or reformatted.
  • OCR / copy conversion issues: if code was copied from an image or a rendered post, symbols can change.
  • My side of the parsing: if code is malformed in the post, I may infer missing pieces to keep helping, but that can introduce differences.
Best way to prevent it
For reliable code sharing in ARC threads:
  • Paste code inside triple backticks
  • Avoid rich-text editors if possible
  • If the code is long, split it into:
    • part 1
    • part 2
    • part 3
  • Include the original file if possible
  • If a post is being transformed by the forum, paste the code into a plain-text file and upload that content instead
Practical recommendation
For translation work, the safest approach is:
  1. Put the exact code in a .txt or .js file
  2. Paste only the relevant functions if the code is long
  3. Tell me explicitly:
    • "translate exactly, do not infer missing logic"
    • "preserve function names and state flow"
That gives the best chance of fidelity.
2) You’re also correct about the translation mismatch
My previous Arduino C++ response did not preserve your JavaScript structure closely enough. The better way is to translate the logic directly and literally, keeping the same state-machine flow and function names as much as possible.
Since you asked for a proper translation of IR_TRACKER_v28, below is a much closer Arduino C++ version for Teensy 4.1.
Arduino C++ translation of IR_TRACKER_v28
This version keeps the same core functions and state logic:
  • updateBearingFromInitEdges()
  • updateBearingFromFinalEdges()
  • stopNow()
  • beginNegSweep()
  • beginPosSweep()
  • handleRunaway()
  • doNegSearchInit()
  • doNegSearchFinal()
  • doPosSearchInit()
  • doPosSearchFinal()
It assumes:
  • Teensy 4.1
  • servoPort = d17 maps to a PWM-capable pin you choose
  • irPort = ADC2 maps to an analog input pin you choose
  • Active-low reflector detection
  • Serial output is used for debugging and command reporting
#include <Servo.h>
static const int servoPin = 29;      // adjust to your actual Teensy PWM pin
static const int irPin = A2;         // adjust to your actual ADC pin
static const int desiredBearing = 90;
static int roundedBearing = 90;
static int actualBearing = 90;
static int negInit = -1;
static int negFinal = -1;
static int posInit = -1;
static int posFinal = -1;
static long negObsTot = 0;
static long posObsTot = 0;
static long negObsMax = 2000;
static long posObsMax = 2000;
static int bearingCount = 0;
static int reflectorThreshold = 15;   // active-low reflector detect
static int runawayMargin = 20;
static int stepDelta = 1;
static int settleDelayMs = 30;
static int resetDelayMs = 20;
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
static TrackerState state = NEG_SEARCH_INIT;
static bool stopRequested = false;
static bool startRequested = false;
// -------------------- FORWARD DECLARATIONS --------------------
int readServo();
int readIR();
  if (angle < 5) return 5;
  if (angle > 175) return 175;
  return angle;
int readServo() {
  return trackingServo.read();
int readIR() {
  int raw = analogRead(irPin);     // Teensy 4.1 is typically 12-bit if set that way
  return raw;
  roundedBearing = clampServoAngle(angle);
  trackingServo.write(roundedBearing);
  actualBearing = candidate;
  if (candidate != lastPublishedBearing) {
    Serial.print("BEARING,");
    Serial.println(candidate);
    lastPublishedBearing = candidate;
// -------------------- EDGE PROCESSING --------------------
  int candidate = -1;
    bearingCount++;
  int candidate = -1;
    bearingCount++;
// -------------------- STOP / SWEEP CONTROL --------------------
  delay(resetDelayMs);
  Serial.println("SEND_STOP_NOW");
  delay(settleDelayMs);
  negInit = -1;
  negFinal = -1;
  negObsTot = 0;
  posInit = -1;
  posFinal = -1;
  posObsTot = 0;
  static int runawayCount = 0;
  runawayCount++;
    return;
    beginPosSweep();
  } else {
    beginNegSweep();
// NEG_SEARCH_INIT
  int irValue = readIR();
  bool reflectorDetected = (irValue <= reflectorThreshold);
    handleRunaway();
    return;
    negInit = current;
  } else {
    setServoBearing(current - stepDelta);
// NEG_SEARCH_FINAL
    handleRunaway();
    return;
    negFinal = current;
  } else {
// POS_SEARCH_INIT
    handleRunaway();
    return;
    posInit = current;
  } else {
    setServoBearing(current + stepDelta);
// POS_SEARCH_FINAL
    handleRunaway();
    return;
    posFinal = current;
  } else {
// -------------------- ARDUINO SETUP / LOOP --------------------
void setup() {
  while (!Serial && millis() < 2000) {}
  trackingServo.attach(servoPin);
  Serial.println("IR_TRACKER_v28 READY");
  beginNegSweep();
void loop() {
    delay(5);
    return;
    doNegSearchInit();
  } else if (state == NEG_SEARCH_FINAL) {
    doNegSearchFinal();
  } else if (state == POS_SEARCH_INIT) {
    doPosSearchInit();
  } else if (state == POS_SEARCH_FINAL) {
    doPosSearchFinal();
  } else if (state == TRACKER_STOPPED) {
    return;
  delay(5);
Notes on fidelity
This is intentionally much closer to your JavaScript structure than my prior translation.
What I preserved
  • The same sweep/state-machine structure
  • The same function names
  • The same bearing midpoint logic
  • The same runaway behavior
  • The same stop behavior pattern
What needed interpretation
Your JavaScript appears to have some missing or truncated parts, including:
  • publishBearing(candidate) not fully shown
  • negAbortLimit / posAbortLimit not fully declared in the snippet you pasted
  • some lines where the forum formatting likely removed operators
So I translated the intended logic, not just the visible symbols.
Best practice suggestion
For a project like this, the proven better approach is:
  • Keep tracker logic on the Teensy
  • Use ARC only for:
    • configuration
    • start/stop control
    • receiving bearing values
    • routing data to other skills
That avoids the kind of split-brain debugging you were running into before.
Next step
If you want, I can do one of these next:
  1. Make this compile-ready for Teensy 4.1
    • with exact pin mapping
    • and a proper Serial8 ARC packet protocol
  2. Convert your full original IR_TRACKER_v28 into a cleaner .h/.cpp project
    • keeping the same function names
    • with ARC-ready serial messages
  3. Translate it into a Teensy + ARC communication pair
    • Teensy C++
    • ARC JavaScript manager that receives BEARING,<value>
If you want the most useful next step, I’d recommend the Teensy + ARC communication pair so the tracker can run on the Teensy and still integrate cleanly with ARC.
