Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Brazil
Led Over The Sound Servo Control
Hi there. Im building my first Robot and Im very impressed about the possibilities on the EZ-B.. At this point I really need a help. Im trying to use some leds to lipsync the sound that comes from the sound board (its the robots mouth...). Well, I hooked up the led on a digital port and use the sound servo control... the problem is: the LED NEVER GOES OFF! Even when the value is Zero. And the other problem. It responds to the MIC signal, but not to the soundboard... can someone help me on that ? thank you! best regards from your friends in Brazil.
#17
That is coming out awesome! I really like the look of it.
#18
@tevans your robot is looking very heroawesome! what size/torque motor are you using for the shoulders? DC motor or servo? :)
Brazil
#19
Thank you friends. I'm using a pair of heavy duty servos for shoulders and two micro servos for elbows.. I'm thinking about put some micro servos on the wrists too, but I'll have to wait the acrylic hands to see if they can lift that...
