Hello guys this is a improment over the past tutorial posted for converting a PC power supply to be a bench 12 volt supply. This tutorial uses the same computer PSU to make a adjustable 0 to 24 volts. This means testing equipment of different voltages will be much easier. Now you don't need to hunt down a ad adapter and cut it up only to find it's not really the voltage you needed.
jstarne1
— Edited
5 Participants
I just jump the green and black wire to power on my old PC power supplies...
Sweet trick RR. I remember years ago reading about this jumper method. Back then I never really understood what wires to jumper. This is a lot better then having a big 3.5 floppy drive strapped to the top of my old ATX like a big humpback. LOL. Thanks.
I have mine installed on the wall in the workshop... gives me some helpful access when I need it!
