HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Instructable - 0 -24 Volt Adjustable Power Supply How To :)
Hello guys this is a improment over the past tutorial posted for converting a PC power supply to be a bench 12 volt supply. This tutorial uses the same computer PSU to make a adjustable 0 to 24 volts. This means testing equipment of different voltages will be much easier. Now you don't need to hunt down a ad adapter and cut it up only to find it's not really the voltage you needed.
Thanks Mel I was going to suggest that! That's what I believe I will do with mine so I can avoid using a meter
New Zealand
Here's one I've purchased that gives me most of what I need at this stage... check it out!
It uses the ATX supply and routes the -12, 3.3, 5 and 12 volt ATX outputs to screw terminals, each protected by a 1.25 amp resettable polyfuse.
dangerousprototypes.com/docs/ATX_Breakout_Board
Hi. Where the ceramic resistor goes. I'm confused goes to the 24 v outlets or to any red and black wire?. Got stuck here Thanks for any help
New Zealand
I never used it... apparently it was an optional extra.
Worked fine for me without it.
Looks like it goes between the + and- wires coming from the pot. Red and black lines in the picture.
New Zealand
#15
According to their site Dave the load resister was needed in some supplies to start the unit... not needed in most supplied but included as an extra. Nice of them in my opinion.
"A 9 Watt load resistor is included but not soldered to the board. In our experience most modern ATX supplies don't require a significant load on the 5 volt rail to start. An artificial load just wastes electricity and creates unnecessary heat. Please let us know your experience."
#16
Ahh, right. I forgot some older ATX power supplies need load to start up. I actually have one sitting on my workbench shelf I sometimes use for bench testing. I needed to hook up an old 3.5" floppy drive to get it to run. LOL. ;)
