Hello guys this is a improment over the past tutorial posted for converting a PC power supply to be a bench 12 volt supply. This tutorial uses the same computer PSU to make a adjustable 0 to 24 volts. This means testing equipment of different voltages will be much easier. Now you don't need to hunt down a ad adapter and cut it up only to find it's not really the voltage you needed.
jstarne1
— Edited
5 Participants
hmm.... Interesting. GREAT Tutorial!
you could place a small voltmeter in PAR and an ampmeter in series and watch the voltage or the amps as you adjust the pot.
Here is the YouTube video for the author. Hopefully you found this useful I plan to make one of these myself as it would be very useful.
