Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Thanks for the quick reply. Simple is good. I will try the dremel.
Or any USB camera will work if it's an onboard PC:). ARC uses USB cameras as well, in case you wanted to use one that fit the eye better according to other inmoov users.
Thanks Dj, that's a great alternative. I will likely add a notebook to the build later. For now i just want to get his head and upper torso assembled and tested quickly to verify things are built correctly and working as planned....also its the only camera i have for now ? I will try Bob Houston's idea this evening and maybe post the results if anyone is interested. Thanks again guys! Super excited by the idea of bringing together the ez-b and the Inmoov project so the speedy replies are very helpful and much appreciated.
