Feetech Serial Bus Servo icon Feetech Serial Bus Servo — Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration. Try it →
I Would Like To Join Actively This Community But Need Your Help To Get Started :
Hi all, (I'm new here) First of all, I'm a big fan of the Ezrobot concept and can't wait to get my hands on the hardware. I'm 35 years young and have a bachelor degree in electronics. I would like to share my knowledge and passion for robots with my sons in a playful way. I was looking at the Aurora Reprap Z605 for 3D printing because it's very cheap. Does anyone has experience with this model? Is it feasible to print in 3D without any other device to smooth the surface and still be able to easily assemble and disassemble the Ezbits?
My end goal is to have at least 2 "fighting" bots to compete with my boys in a robot battle. To this end I would like to equip a six and a roli with a scorpion tail (on the front) to be able to flip an opponent on his side. In a second phase I would like to mount a humanoid head on both of them which I would like to equip with an IR emitter and receiver to be able to shoot at each other. Does anyone has any experience in this kind of application?
I'm really looking forward to start building and configuring these robots. I thank you in advance Nicolas
hi nicolas i am from belgium to (antwerpen)
what are you using a pc or? whits pc do you have.
patrick
welcome to ez-robot forum.
j
Hello Nicolas Pirotte ,
Welcome to the community. As far as smoothing out the ez-bits, you can use sand paper on 3d printed objects and it works well. You can also trim the parts with an exacto which works well.
It is my experience that you will need to do a little cleanup on the parts. If you buy the parts from EZ-Robot, they will be injection molded and much stronger than 3d printed parts, which is the way I ultimately decided to go. The layering in the 3d printed parts works for a while but eventually weakens and cracks. I suppose if you were going to connect them and leave them connected, you would probably not have this issue, but mine were connected and disconnected many times for demonstration purposes of EZ-Bits.
Welcome! Just as an idea, I'm looking into the xyzprinting da Vinci 1.0 3D printer. Cheap with quality prints.
Thanks for the quick reply! Great advice indeed! It would be a lot faster and cheaper to be able to print parts myself. I assume there is no reseller for EZBits in Europe, is that right?
Patrick : The laptop I'm planning to use is a Dell i5 core @2,6Ghz, 8Gb RAM, Win 7 pro 64bit. Do you have experience ordering @ Ezrotbot from US? Can you recall if you had to pay a lot extras? (VAT, customs import taxes, transport)
KR Nicolas
hi nicolas ,i only paid amazing 24.50 euro that all
Welcome Nicolas!
We drop ship the products from china directly to you - so there is no need for a reseller. Although we have a list of resellers coming online very soon.
Do keep in mind that Roli body is the only robot you cannot 3d print. He has too many gears, metal axels, clips and other complicated parts which are not 3d printable.
