BN-880 GPS Compass icon BN-880 GPS Compass — Standalone autonomous navigation using Beitian BN-880 GPS/Compass with real-time map waypointing and offline map caching; requires Arduino. Try it →
France
Resolved Resolved by Aerius!
How To Connect Inmoov On Ezbv4 ?
Hello to everyone in this forum ... First I want to thank all the contributor on EZBv4 with Inmoov ... I'm more comfortable with the French language than English so I apologize in advance for my mistakes of understanding ...
I am a user and inmoov myrobotlab and my inmoov robot is under construction ... Currently I only have the stomach to realize ... By cons I have a big worry I'll explain briefly here: I managed to connect all servos except my biceps and servos of the clavicles because I have a hard time fixing my square potentiometer outputs HS805BB servos. Unfortunately after several attempts I did not happen.
My servo biceps continues its course without stopping despite the setting and adjustment of the potentiometer in place. I should probably take me wrong but I must admit that this part of construction and setting is really tricky ...
I heard this week that it is not necessary to remove the HS805BB servo potentiometer using EZBv4 interface! Can you confirm it to me? because if that is the case I have already ordered a kit to use my EZBv4 Inmoov Robot with this wonderful wifi interface ... Someone could tell me how you properly connect its inmoov a EZBv4? Have you a tutorial or a connection diagram to show me?
Thank you in advance for the help you can give me so that I can finish my robot...
La position 0 donne par Gael n'est qu'un point de reference qui correspond au positionnement de l'avant bras avant que celui-ci ne se brise.
Ce qui importe: 1- Que le potentiometre puisse tourner librement pour couvrir le mouvement en entier
2- Trouver les valeurs minimum et maximum a donner au servo pour couvrir le mouvement.
(ce qui peut etre fait dans ARC ou Myrobotlab)
extrait de Myrobotlab:
voici 2 photos qui montre comment le pot est installe et aussi la plage couverte par celui-ci.
Et finalement, la charte de connections de mon Inmoov
@Dj Sures : Thank's for your attention .... Yes, the App of bhouston, I had seen in the cloud and download already but I wanted to ask him if I could used his app by respecting the same connection on EZBv4 ports and whether there have a connection diagram...
@Aerius : EXCELLENT ! Merci infiniment de ton partage et pour avoir pris la peine de faire des photos tres clair avec cette charte de connexion qui pourrait aider a la comprehension pour les nouveaux venus comme moi...
Je constate que tu as fixe le potentiometre avec les fils vers le haut... Comment l'as tu bloque? avec de la colle ? car je n'ais pas vu de vis de chaque cote du potentiometre...
Utilises-tu une app perso pour Inmoov que tu as partage sur le cloud EZB ?
En tous cas je pense pouvoir avancer maintenant avec ces informations...
(bravo pour les pieces du robot qui ont l'air d'etre tres bien imprime avec une superbe precision et le rangement de tes fils a l'aide de gaines, ce qui fait tres propre...)
@MrENCROS Merci pour les compliments.
La seul application utilise pour mouvoir les servos, de mon Inmoov est ARC installer sur mon pc qui lui controle par WiFi le controleur EZB-V4.
Les lecons d'apprentissage https://www.ez-robot.com/Tutorials/Course/6 et les divers tutorial https://synthiam.com/Community/Tutorials/ developpees par les usagers de ce site te seront d'une grande aide.
Tu verras une fois que tu sera familier avec EZ-Buider, donner "vie " a ton Inmoov sera tres facile.
@MrENCROS, I listed all of my servo port connections on a Notepad in the program on EZ- Cloud. ( It's on screen 2 ) Be careful when using my scripts, even though you may connect everything the same way as I have, your servos could be calibrated differently so they may not move correctly to my scripts. You could break something. You are more than welcome to use anything that I or anyone posts to the EZ- Cloud - that's why it's put there. Have fun!
Voici la charte de la distribution des alimentation des servo-moteurs de mon Inmoov.
A noter: 1- Tout les point communs (mise a la terre) doivent se rejoindre.
2- Des alimentations differentes pour les EZB et les servo-moteurs assurent une plus grande stabilitee
InmoovPowerdistribution.pdf
#15
@bhouston I Thank You for sharing your application ... Dice reception of my EZBv4 I will try that and I will show you a little video of my robot...
@Aerius C'est exactement ce que je voulais consulter ici !
Merci infiniment pour votre travail avec ce schema PDF d'alimentation sur Inmoov vers EZBv4. Avec le tableau que tu as poste plus haut + ce PDF de connexion, c'est un parfait exemple pour savoir comment connecter le robot Inmoov sur une plateforme EZB. Ca aideras surement ceux qui veulent essayer sur EZB et qui tomberons sur cette discussion... J'indique ce topic comme resolu...
J'ai 3 petites interrogations : 1-Je remarque 2 EZBv4....Je suppose qu'il en faut 2 pour connecter tout les servos du robot ?
2-Il y a 6 interrupteurs on/off...est-ce necessaire pour chaque partie du corps ? (1-cote gauche/2-cote droit/3-tete/4-estomac et torse/5-EZBv4 et le 6? )
3-Tu utilise une seule batterie de 6 Volts pour la totalite? ou bien une aussi une autre alimentation uniquement pour les EZBs ?
#16
J'indique ce topic comme resolu par Aerius et bhouston...
