I have two kits
I am trying to run all four continuous servos
Only can get two to run
Sabertooth Movement Panel
— Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
I have two kits
You will need to be more specific. Are you using a modified servo movement panel?
Yes
But only allows 1
also my wheels will not stay on the servos
You will need to use a long screw or a dab of hot glue to keep your wheels on the servos. While building a robot, there will be plenty of creative solutions to exercise your mind.
There is no native support for more than 1 modified servo per side.
As you are trying to do something custom, you'll need to dab into EZ-Script.
Use this example to demonstrate how it can be done: EZScript-Examples-MultipleModifiedMovementServos.EZB
Note: it is mandatory that you use proper subjects for your posts. Posts with vague title subjects do not benefit others who are looking for similar assistance. Moderators will remove posts with vague titles and subjects. Please review the forum rules
Thanks!
My Test Bot runs 4 continuous servos. See the attached project for another example using a different method.
testbot.EZB
Thank you so much for your help folks
Oh smart Rich! Good idea to use the custom movement panel. I never thought of that. That's probably a better way than mine!
Also you could use a rc servo Y adapter on each side so two continuous servos get the same signal from one digital pin. Its basically paralleling and you can make your own Y cable with a piece of heat shrink and a bit of solder from two servo ext cables.
Of course I'm assuming you still want to use the basic right and left skid steering and forward/ reverse most robots use - Josh S
