PWM Servo Feedback (I2c) icon PWM Servo Feedback (I2c) — Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining. Try it →
Horizontal/vertical Servo Control
Horizontal/Vertical Servo Control
I ran into this once before and never did figure out exactly how I got it working. When I add either a vertical or horizontal servo control, I don't get a slider nor can I move the servo. Adjusting the settings moves the servo ok, but then there is nothing in the panel to move it. I'm sure it's something simple I'm overlooking.
Make sure the values aren't reversed in the settings. Other than that I'm stumped.
Post your project and I'll check the settings out.
The only other thing I can think of is there may be some multi servo settings in play. Check the multi servo settings too.
The video I posted starts a new project, adds the servo control, changes the settings and shows the control working. Those are the steps needed when adding a servo control, you must change the settings, by default it is set for a min and max of 50 which must be changed.
