I got my head all back together and the neck, etc. I have a battery going through a 640 ohm resistor to a female extention plug. I plug this in to test the LEDs. Each one worked very good but one did not. I checked reverse polarity on the circuit and the LED worked. I did not want to take the head all apart again (hassel). So , I simply turned the plug around not realizing if i were hurting something or not. But, it did not seem that it would damage the EZB because I was simply swapping ground and signal. I can't see very well, I may have plugged a plug in shifting one pin over. that would connect ground to hot or signal to hot.
Anyway, boiling it down, All of my digital pins do not work anymore.
Any ideas? I am thinking voltage regulator blown, I hope it is not the cpu. I am going to run the test that D.J. has and try to figure it out. The lights blink red and blue and it connects up. So , the bluetooth is working.
Wish me luck.
@mel that's why you should keep a spare board ! Lol I'm impatient to the max so I understood. I would suggest you let mark ( or appropriate representative) get the board repaired for you. This way there is no guessing and you know it's 100 percent repaired.
@jstarne1 Ha ha, no way I will be touching that board! The goal is to get it fixed, not turned into a permanent paper weight!
@ Mark , Sorry! Lol I haven't had much interaction with you since you came aboard EZ-Robot so I wasn't sure of you role. Epic soldering skills might not be on the resume
@mel I mean if you can send it in the the factory I would do that.
It costs too much. Unless you want to put a downpayment on your turtlebot.
@jstarne1 Im strictly on the business side... more then likely it would be Jeremie.
Ohhhhh noooooo, don't tell them my real name.....my secret identity will be revealed!
@mel have you already ordered/ purchased the voltage regulator?
I have ordered the new version4. I plan to get the regulators at radioshack today. I hope they have both of them.
