TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Russia
Help Me
Detailed information about the operational use of (JIT) debugging instead of this dialog the window contains at the end of this message.
************** The exception text************** System.NullReferenceException: object Reference not set to an instance of an object. ? System.Speech.Recognition.SpeechRecognitionEngine.InstalledRecognizers() ? EZ_B.SpeechSynth.GetInstalledCultures() ? .(ConfigurationFormV2 ) ? .(ConfigurationFormV2 ) ? .(Object , EventArgs ) ? System.Windows.Forms.Control.OnClick(EventArgs e) ? System.Windows.Forms.Button.OnClick(EventArgs e) ? System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) ? System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) ? System.Windows.Forms.Control.WndProc(Message& m) ? System.Windows.Forms.ButtonBase.WndProc(Message& m) ? System.Windows.Forms.Button.WndProc(Message& m) ? System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) ? System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) ? System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** ??????????? ?????? ************** mscorlib ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.34014 built by: FX45W81RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder ?????? ??????: 2015.5.16.1 ?????? Win32: 2015.05.16.01 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-Builder.exe
System.Windows.Forms ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.34003 built by: FX45W81RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationCore ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.34004 built by: FX45W81RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.34004 built by: FX45W81RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
EZ-RibbonMenu ?????? ??????: 2015.4.29.0 ?????? Win32: 2015.04.29.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-RibbonMenu.DLL
EZ_B ?????? ??????: 2015.5.16.0 ?????? Win32: 2015.05.16.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.34230 built by: FX452RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
Accessibility ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
mscorlib.resources ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_ru_b77a5c561934e089/mscorlib.resources.dll
System.Core ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Web.Services ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Microsoft.GeneratedCode ?????? ??????: 1.0.0.0 ?????? Win32: 4.0.30319.34230 built by: FX452RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.resources ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_ru_b77a5c561934e089/System.resources.dll
System.Windows.Forms.resources ?????? ??????: 4.0.0.0 ?????? Win32: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_ru_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Operational debugging (JIT) ************** To connect operational (JIT) debugging file .config this application or computer (machine.config) must have the jitDebugging value set in the partition system.windows.forms. The application must also be compiled with the included debug.
For example:
When JIT debugging any unhandled exception sent to the JIT debugger registered on the computer instead be handled by this dialog.
Does your speech recognition work in Windows? Test it by following these steps...
  1. Open Control Panel
  2. Select Speech Recognition
  3. Select "Take Speech Tutorial"
what are your results?
here is the video he made.
Thanks Nomad for fixing his video.
I'd go back to post #10 from DJ and make sure voice recognition works under Windows. From the video we can see the mic works and sound recording seems to work, but we don't yet know if speech recognition under Windows works.
