EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
looks good, but just remember not to travel to anywhere where you cant get the 1.21 gigawatts of electricity. People have gotten stuck that way.
How do you connect the HC-SR04 Ultrasonic Distance Sensor to the board?
I got a development kit and I think it already comes with a voltage regular, I am not sure a) where to connect it b) in the builder how to add it.
Below is a picture of what mines looks like.
you will use 2 digital ports.
on the first port black to black white to white red to red
on the second port green to white.
You will then need to set the ports up in ARC depending on which control you are using.
either the first or the second port will be send. the other one will be receive.
#15
Thanx DJ:) wired as normal to the +/- wires?
