Thanks Dave.
I knew I was over-complicating this (like I do). By having the spinning unit push the door open I could not only save a servo but port connections and controls as well. My spinner is attached to an actuator and slides out of a guide created from PVC inside the tractor. I think I may follow your lead.
:D
Daniel
glad you found this helpful. As a side note, don't let the scoop start spinning till after its cleared the door. It looks better and causes less ware to the parts hitting each other.
