Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
Great Deals From Brookstone
While supplies last, in addition to the BOGO deal, and regular internet discounts and/or free shipping coupon codes, they are also including extra stuff in orders if you order uneven numbers. The BOGO deal is mix and match, but they have already packaged things in packs of two. I ordered 3 rotation and 5 lever servos. I got 4 rotation and 6 levers with no extra charge for the two extra servos and was able to use a 15% off and free shipping coupon codes.
Obviously not something you can count on, but if you needs servos anyway or the other EZ-Bits they sell, might as well do a ix and match so the individual types are uneven and you could luck out too.
if anyone knows:
  1. the JD kit as the camera inside the head, it's possible to buy the plastic case to fit the camera and use in a Six ?
  2. I read somewhere there was new version of the EZ camera how can i identify if i have the new one ?
Brookstone did not get the new camera. The old one is a 2 board design, the new one is one board and a big heat sink.
You can try contacting EZ-Robot to see if they can send you just the case for a camera (it is not available in the store) , or the STL is available so you print one or have it printed for you.
check! camera has 2 boards. Thanks for the tip.
