EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Ezb4 Speaker With Pandorabots
EDIT. I just want to mention that anyone looking to do something similar to what I have mentioned in this first post, should look at post #7 for more details, as the wiring details mentioned below are not entirely accurate, and may not be suitable for your needs. ;)
Hi guys.
I have wired up an old headphone socket to my EZB4 "SPKR" terminals and plugged it in to a small rechargeable amplified speaker that I have. The speaker is Bluetooth enabled, but has a headphone socket and the plan is to use this for a semi permanent hardware connection.
Initial tests sounds good when I start up the v4 and tried it with a bit of script. But the issue I need help with is when I use the Pandorabot control. When pandorabot replies, the speech comes through my laptop speaker and not the v4 speaker set up.
I have tried using the "?" On the pandorabot control but was no help. What am I missing to get this working the way I need to confused
Cheers, Steve.
Your welcome Dave. Credit where credit's due (and to the EZ team as well). It is a good Wright up, and very useful. ;)
@JD.
Your timing is spot on. I have been setting up soundboards and sound scripts for K-9 this morning, and just before I did I was playing around with the Pandorabot control. And what did I spy with my little eye in the config menu... an option to play Pandorabot audio through the EZ-B4 speaker.:D:D:D
Thank you sooo much for adding that. It's a great addition to ARC and you implemented it really quickly which is appreciated.
Thanks once again.
Steve. :):)
