MP3 Trigger icon MP3 Trigger — Serial MP3 Trigger for EZ-B: plays MP3s from mini‑SD; configurable port/baud. Deprecated-replaced by EZB v4 streaming audio. 3rd‑party. Try it →
#17
@Nomad.... Read Rich's reply.... You don't need an app for one wifi device to connect to another wifi device... Again, all he did was connect.... since there isn't an app available he really couldn't do much else after that....
#18
The confusion is coming in with how Nomad was connecting to the V4. He was doing everything through the app, including connecting to the network.
Nomad, when we were talking, I had you use your android phone to connect to the V4 outside of ARC. It took a while to find the Settings and then Wifi Networks option on the phone. This is what Rich is talking about. Connecting to the EZ-B V4 from outside of the ARC app. Once connected, you could go to the web server on the V4 through a web browser and see the settings on the V4 for the network. I also had you play some sounds through the v4 from the web page. This is what he was able to do so far.
ah i get it
thank you
#20
@d.cochran... If nomad got that far (the EZB webserver), why wasn't he able to flip it to client mode? What happened?.....
#21
This was from his android and not his pc. his pc hasn't been able to connect to the v4 at all. When configuring the v4 to connect to the network, it cant connect and the android can using the same settings. I also tried with the PC and a separate nic that he had and it couldn't connect either in ap mode, but could connect to the network using these same settings. All firewalls were disabled and the norton web stuff was disabled. Still nothing from the PC. We tried his second V4 and his had the same issues. The goal is to get the V4 on the network in client mode, which the access point that he purchased is know to be fine with the V4, along with the PC. At that point, he will be able to see the V4 from the PC. New and old dont always mix well, especially when one of the two is locked down and you cant see it.
The access point is locked down by the service provider. a new access point that isnt locked down by the provider will allow us to make it work. The old access point is old and should be upgraded anyway (only b mode wifi).
#22
Ok got you... thought if he could use his android to set his ezb(s) in client mode, he then could finally use his pc...
@Nomad... Time to update to some new technology dude....:P
allreddy ordered the new accses point.
