— Edited
8 Participants
DJI Tello Movement Panel
— Control DJI Tello from ARC with live camera feed for computer vision tracking; fly via scripts, speech, joysticks, Python, or Exosphere.
Did i read that correctly ? We can daisychain the new ones together ???
@Wofie, I think you read correctly!
MMMMMMMM that opens many many doors
hehehe
You've always been able to connect up to 5 to one PC, I'm guessing that the EZ-Chain or whatever it is would just simplify that (not to undersell it)
Gnd pins on the outside that's a change round and no heat sinks for the VR's
I wonder how the EZ Chain on one connection will handle projects with a lot of things going on that will require bandwith and computing power. Let's say two boards fully loaded with many servos, camera and ADC montoring. Will the bluetooth handle all that at once for better or worse on one connection?
I do like the lower profile the lack of heat sinks will give. This will help me out a lot. I wonder about cooling. Will this change make the heat disapate to the board? If so will the board get real hot and cause problems. Very interesting changes and looking forward to how these changes will effect the board and how it works in real life.
well theres ups and downs @dschulpius.
Ups to linking: One connection, don't have to fiddle around connecting all the boards. Controls everything through one connection Don't tie up bandwidth with multiple boards
Downs: Slower responces More wiring in an already complex project of wires Requires more out of your PC
