Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
No you actually need a PC, EZ-B communicate with the computer via the bluetooth serial port.
Brazil
Well, you can't save the program on the ez-b (YET!). At this point, you still need and computer. Or you can try an Mini-ITX board, so the entire system fits on your robot body. About the servos, You can set the speed using script.. best regards.
Thank you PJ_Dtechy and tevans, I was thinking of making an autonomous mower with the kit, I will need to rethink all my assembly to be able to add a PC. Have a great day !
Great team work PJ_Dtechy and tevans! Andre99 good luck with your mower. Let us know if you have any questions. :D
Honestly I added a Computer with full size head sink, full sized Nvida graphics card, desktop sized hard drive and dual hard drive caddy ext and fit it into about a cubic foot space.. You can do it. Here is a pic.. This is a 12 inch wide by 14 inch I believe.
A mower should be plenty large to retrofit a PC into. If all else fails just use a Acer 7 to 10in netbook. Those are great too!
Good luck , I would really love to see this mower Project. I don't have my own grass but it sure seems like an awesome thing to have. Imagine just chilling out drinking a cool glass of tea while you supervise your mower in the shade from a laptop. Nice.
Thanks all for your help now and in the future ! I will receive my motors and weel tomorrow, I look forward to make the assembly. jstarne1, impressive fitting, for now I will probably install a laptop I do not use but space will be a big trouble for the final because I will not have a lot of space, I intend to keep the mower complete and just remove the weels and the arm. I will post pictures but it will be slow, I do not have all the mechanical parts yet and the framing of this will be my biggest challenge.
Has somebody try the I2C ? After looking at some data sheet it look like the resistors need to be 5K and not 10K, am I wrong ? I will receive a compass unit next week and it's I2C.
Have fun and thank's again
@Andre99 I believe there are tutorials for using the Blinkim LED which requires I2C commands/interface :).....and I know Rich has used I2C as well....again a Forum search on I2C will help!
