Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
Dynamixel Settings Question
This question is directed to anyone running dynamixels. I am wondering if any of you have attempted or found a way to override the thermal cut off. I've looked thru the Dynamixel wizard and the documentation is lacking to say the least. In a perfect world the ability to turn off these safeties would be ideal.
I'm trying to either override the thermal, default is 70 deg c temp can be set (0-99 deg c) and turn it off OR override that torque goes to 0 when temperature reaches over the thermal cut off.
The Alans I have on the other side of the world are thermal shutting down do to a hot environment. We are going to be working to cool the area but it would be better to override the protections (I'm sure voiding the warranty) or the ability to change the settings in software.
The Dynamixel Wizard will allow you to set thermal cut off anywhere from 0-99 deg c and change the torque settings but I do not have access directly to Alan and would be better to have a software solution. Right now Alans have to be turned off and the motors to cool down for 20-30 min to reset the thermal and bring them back online.
An example of a fix would be adding two buttons to the EZ Robot Dynamixel plug in so one could change the thermal settings and or change the torque setting if thermal limit is reached. I assume those could be added as we can turn on and off the leds, rename Ids and change baud rates within the plug in.
Any help would be appreciated.
you can see the settings for the thermal shut down at 5:05 on this video.
seems good.
EDIT 1: The colors are inverted on the EZB side ?
EDIT 2: It seems they are inverted also on the hub side... Q: Why not match the colors and the pin position ?
can you post a snipet of your dynamixel plugin configuration screen ?
this:
If you read the tutorial, and the posts #14, #16...
I'm without clues.
You need to try the servos with the original vendor software.
Check the Id's and the baud rate.
#48
Ok, thank you a lot I'm trying to finish this project for my BFA last semester in Dec. Have a good night.
