Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
#17
no it comes up as i said and i load the servo config file every day when i open the program and load the project, and most of it saves but there are slight adjustments needed, so its not going back to where it was before i calibrated it its not nearly that off every day but its off a bit and only in the legs and arms
#18
The red arrow points to the check box which enables/disables prompting for servo profile on load.
I also added the blue arrow to point at the examples folder button to help with your other post.
#19
yes that is exactly what i do but as soon as i hit the examples button it gives me an error box saying "could not find path to ....) and i looked around in all the folders and there are not misplaced they are just missing, i have installed it on 2 computers and both did not come with the examples or atleats did not have them after the update i can not be sure
#20
could you please share a zip file with these if they are not online? or email it to me
#21
They are installed with ARC. If they are not in the location I said they should be in then you need to uninstall ARC, reboot and reinstall ARC.
Doing a fresh install of ARC after reboot may also help with some of the other problems that you are having.
#22
that fixed the missing example issue, thanks
and i have uploaded version 2 now
