Bot Libre icon Bot Libre — AIML2 chatbot client for ARC connecting robots to Bot Libre cloud for customizable, private chatbots and personalities. Try it →
rr its in green mode
rich AA rechargeble was recomended here by someone. so you found the problem why its always disconnect.i have two lipo from, here just waiting for the male connector.
thank you all
#42
So the problem ended up being a power problem...? More precisely, not enough of it because @nomad was using AA rechargeables? Hmmm, go figure....
#43
It's unclear if that was the problem or not.
it was because i was using rechargeble AA i order de male wire from the original batt.
#45
Hey Nomad,
I'm not sure it it helps you or not but a lot of RC hobby shops sell the Male Deans connector either by itself or on the end of a wire or splitter (that you could salvage).
Do you have a local RC shop?
i have ordered from ebay,yes we have a local rc chop.
thank you jeremie
dean connector
i kept one original and the other i solder thik wire on.
rich&rr
just wanted to let you know bolt.i do read and try. but its very diff for me at that speed your are working. it was the power source.
thanks
#48
Ok @nomad so remember if the voltage drops below a certain point (I think drop out voltage is just under 5V) the ezb will disconnect and reboot... So when you are using power hungry devices (like servos) with your ezb you need to have a very good battery like a lipo to power it...
