I've received my EZBv4 and changed to Client mode and found the new IP address (192.168.1.15:23), but ARC for windows connects (and i hear sound on EZBv4) but keep disconnecting after a second or two.
Any help would be greatly appreciated - we are trying to use EZBv4 in a science project.
Thanks so much!
Try adding the Debug window to your EZB program and capture the error messages and post them here.
@Will2829, If able assign a static IP address in your router for your EZB. How old is your network router? Others here including myself had to buy a newer router. Have a read through this thread I started when I was struggling with this issue. My setup is running like a clock now:
Connecting To Two V4 Ezb's
You might need a better router.... I had the same problem (constant disconnects). I solved it by upgrading my router........
EZB 0: 8/30/2014 1:58 PM - TCP Server stopped 8/30/2014 1:59 PM - TCP Server stopped
EZB 1: 8/30/2014 1:58 PM - TCP Server stopped 8/30/2014 1:59 PM - TCP Server stopped
EZB 2: 8/30/2014 1:58 PM - TCP Server stopped 8/30/2014 1:59 PM - TCP Server stopped
EZB 3: 8/30/2014 1:58 PM - TCP Server stopped 8/30/2014 1:59 PM - TCP Server stopped
EZB 4: 8/30/2014 1:58 PM - TCP Server stopped 8/30/2014 1:59 PM - TCP Server stopped
8/30/2014 2:01 PM - Attempting connection on 192.168.1.15:23 8/30/2014 2:01 PM - Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.EZB.(Int32 , Byte[] ) 8/30/2014 2:01 PM - BbytesToExpect: 1 8/30/2014 2:01 PM - U Received: 8/30/2014 2:01 PM - Disconnected 8/30/2014 2:01 PM - Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 8/30/2014 2:01 PM - Disconnected
Router is pretty new (< 1yr)...Netgear high end
Another piece of information that might be useful is that I can connect via my web browser at the 192.168.1.15 IP address just fine and do diagnostics (activate sounds remotely).
Hi @Will2829,
What do you have running within your ARC project when you try to connect?
Disconnect and no connect issues:
On top of checking your router, you will want to look into your anti-virus software also. I have discovered that AVAST hates ARC.
Avast will:
This has been confirmed on 2 Windows 7 64bit computers and 1 Windows 8 computer.
AVG Anti-virus has no issues with ARC
