Stream All The Video Sources icon Stream All The Video Sources — Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback. Try it →
If the servo is under stress it will get hot. If it's faulty it will get hot.
With the servo held so there is minimum stress on it, does the servo get as hot as quickly?
Is the screw in the shoulder too tight? Which may cause high friction when it is moving.
its from roli choulder servo
i changed the two servo whit news ones same result rapid getting hot.
