Text Overlay icon Text Overlay — Overlay a variable on a processed camera image at X/Y coordinates; name the variable and attach to a specific or any available camera Try it →
Cannot Update Firmware
Hi, I just got my kit and was attempting to upgrade the firmware (ARC prompted me to upgrade). I start the upgrade application and I can connect to the board. The application says: Press the HELP menu option to watch a video about this Firmware Upgrade process. Otherwise, press UPDATE when you are ready.
4/27/2013 7:58:20 PM - Sending bootloader Starting Boot Loader...
4/27/2013 7:58:27 PM - sending ping 4/27/2013 7:58:29 PM - sending ping 4/27/2013 7:58:31 PM - Sending bootloader I am EZ-B BootLoader. Gimmie Firmware!
4/27/2013 7:58:38 PM - Step 1 of 2) This process will take 2 minutes. The status bar will display progress.
4/27/2013 7:58:38 PM - Updating... (22,656 Bytes)
But I get an error message from windows and the program quits, heres what the windows error says:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.InvalidOperationException: The port is closed. at System.IO.Ports.SerialPort.DiscardOutBuffer() at .(Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-B Firmware Update Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ-B%20Firmware%20Update.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Any ideas?
Thanks.
No I don't although am asked that often, and always with the same reply which is basically, if this was a job I wouldn't enjoy it anywhere near as much. Helping is it's own reward:) Plus I earn respect (well, from most people with the odd exception best left unmentioned) which is cool and beats attempting to demand it:D
Search for JY-MCU, they are stocked in other stores.
Ok, thank you. I really admire what you do. This is really great. Simply true and good. And indeed, you do not need to bother about the unmentioned guys... and you and me know that I know at least one of them... He's so funny!
Uganda
Hi, mine cant update its firmware as well, and I have also realized that the blue led does not light up as well...and yet I just actually received my EZ kit:(
From my recent experience you'll have to pay for return shipment AND the shipment for sending you a new one... 20$ Each so at the end you just pay almost for a new EZB that you would get much much faster (and at a substantively cheaper shipping cost) from a third party online retailer that ships it from their stock. Therefore it will take like a month before you get the new board because it's being shipped from China... This is the only flaw I found with this company so far, but I think it's a big one because it means that if you get a defective board, since it is close to impossible to prove it was defective from the beginning... you're kind of inevitably going to pay for its defect. In my case they said that the firmware upgrade might have been interrupted at some point while my device could connect twice before it stopped accepting connection, which makes their assumption a simple non-sense. I had not even had the time to imbed it into my project, I was still at this stage when you try few connections and check that digital ports respond properly (since you don't want to figure this out after having wired everything to the board). Basically customer care has to improve and upgrade itself to better standards. I guess this is what happens when a company has yet to reach a higher turnover revenue.
@malep, have you successfully paired the EZB to your PC? Have you tried all COM ports that were added on successful pairing? What error message(s) are you getting? What bluetooth stack is installed? Is there any third party bluetooth software installed? Is the red light on the bluetooth module flashing, solid or nothing? Are your batteries charged? Have you followed the EZB diagnostic tutorial? Too many questions all at once?:)
Try/check all of the above. If you still have problems use the Contact Us page to report the problem.
#15
After doing so you can also connect the tx and Rx on your board (after pulling out the bluetooth module) to a USB to TTL module, if you have one, and attempt a connection to your EZB using this device's COM port. If you get a connection then it's definitely your BT that needs to be replaced.
#16
@elfege, you can order a class 1 bluetooth from Sparkfun.com. Reasonable shipping fees since they are US based. While on the web site go ahead and order a 6 pin header to solder to the bluetooth module. The center 4 pins are identical to the 4 pins on the EZ-Board.
HERE is a link to the actual bluetooth device.
