Openai Chatgpt icon Openai Chatgpt — ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API Try it →
Cannot Update Firmware
Hi, I just got my kit and was attempting to upgrade the firmware (ARC prompted me to upgrade). I start the upgrade application and I can connect to the board. The application says: Press the HELP menu option to watch a video about this Firmware Upgrade process. Otherwise, press UPDATE when you are ready.
4/27/2013 7:58:20 PM - Sending bootloader Starting Boot Loader...
4/27/2013 7:58:27 PM - sending ping 4/27/2013 7:58:29 PM - sending ping 4/27/2013 7:58:31 PM - Sending bootloader I am EZ-B BootLoader. Gimmie Firmware!
4/27/2013 7:58:38 PM - Step 1 of 2) This process will take 2 minutes. The status bar will display progress.
4/27/2013 7:58:38 PM - Updating... (22,656 Bytes)
But I get an error message from windows and the program quits, heres what the windows error says:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.InvalidOperationException: The port is closed. at System.IO.Ports.SerialPort.DiscardOutBuffer() at .(Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-B Firmware Update Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ-B%20Firmware%20Update.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Any ideas?
Thanks.
#17
Thank you Rich. In the meantime I gave up since it came to almost the price of a brand new EZB, so I ordered one from another site and got it in less than a week. Thanks again.
Uganda
#18
@Rich, I have done everything on the list to the dot... still not working :-( guess I might just have to purchase another EZ kit
#19
Use the Contact Us page and let them know the problem, they should get back to you about servicing it. Be aware that both Alan and DJ are away on holiday at the moment so be a little patient.
