MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Resolved Resolved by Athena!
Can ARC work with an Lattepanda/Arduino with a PCA9685 connected to it?
Can ARC Work With An Lattepanda/Arduino With A PCA9685 Connected To It?
Can ARC work with a Lattepanda's Arduino with DJ's firmware installed with a PCA9685 connected to it to control servo's in the following connection model?  Note UNO represents the Lattepanda's Arduino GPIO.
I would be connecting to pin 6 for A4 and pin 8 for A5
Will the standard servo skills work in ARC if ARC is connected to the Arduino or is something else needed? Like the PCA9685 16-Channel PWM Driver Module Library loaded on the the Arduino?
Lattepanda by DF Robot
LattePanda with Synthiam ARCx runs headless, loads EZB firmware on the built-in Arduino, and controls robots from any browser
Servos 12
UART 1
ADC 5
Digital 12
#2   — Edited
This post did not have any relevant information so I removed it.
#3   — Edited
Yes, I modified the Mick's software and loaded it to my "Arduino uno", and it worked just fine with all the info above. You did watch the video? I used it with the ESP32
I put : // Creat object to represent PCA9685 at default I2C address Adafruit_PWMServoDriver pca9685 = Adafruit_PWMServoDriver(0x40);
Try loading Mick's software to an Arduino  "as is".
I not using a Lattepanda , but The instruction say: download the Arduino firmware below. You can program on the Arduino Leonardo that's built into the LattePanda. Adding this firmware lets you connect ARC to the local Arduino and directly control the GPIO.
DJ's instructions - Download Arduino Leonardo Firmware: EZ-Genuino_Leonardo.zip. Last updated 2022/08/24
I just used my Arduino uno with Micky's software modified, compile fine, I don't have my PCA 9685 here so I can't use it here at the farm, but I know it works
Most Arduino have a SDA or SCL
Remember - Nothing would move until I added a separate 5 to 7.5 v power supply, I use on the PCA 9685 above
#4   — Edited
Removed as no longer correct
did you get it to work yet?
I have not tried it yet I need to pull the Lattepanda out of my V1 head first and setup some type of test bed for it.  Space is a bit of an issue for me at the moment.
Sounds good,
I just tested the Arduino uno (with the Arduino code) and the PCA9685 with just 8 servos, as you can see, it works well
thanks, smiller29 for the email
Your community post was liked by smiller29.
