MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Benefit of onboard computer
Benefit Of Onboard Computer
Hello to all the members of the community here.
I am starting to build an InMoov robot project using ezb controllers and want to understand what if any is the benefit of adding a onboard computer to the project is?   Also what computer configuration would be best to use?
Currently I am going to be using a IoTiny in the head and two ezb4’s in the chest.
#33
Quote:
The biggest benefit of adding a onboard computer to the project is that your computer will be set up and working right away
Agreed. However these SBC boards take a long time to boot into Windows and start up ARC. Once you are into Win and want to work in the interface, there is also a lag in the time you click on a menu or button and the response. However data seems to be sent to your EZB quick enough.
Another advantage (may have already been motioned) is that if you can hard wire connections to EZBs through USB you don't have to run data through your home WIFI or use WIFI AP mode.
