Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Hi Nomad 6R
Thanks, I had seen this but it is not the same thing.
#19
@Holy1 not using a single auto positioner you can't ... Just write simple scripts (using the cheat sheet/control commands) to drive frames or actions on 2 or more different boards. This way you can can control one or more auto-positioner controls at once... e.g... Fingers move in one auto-positioner at the same time head moves in another auto-positioner control... and so on...
@Richard.
Thanks, I will work on that as learning scripting is next on the list as my Inmoov is ready to go ( as much as I am going to do for now) .
#21
Yeah - create a different Auto Position for different servo groups. Such as one for the fingers, and one for everything else...
then you can execute them like so in ez-script..
ControlCommand("Auto Position Body", AutoPositionAction, "Arm Down")
ControlCommand("Auto Position Fingers", AutoPositionAction, "Fingers Out")
# Wait for auto positions to complete
sleep(500)
waitfor($AutoPositionStatus = 0)
ControlCommand("Auto Position Fingers", AutoPositionAction, "Peace Sign")
sleep(500)
ControlCommand("Auto Position Body", AutoPositionAction, "Arm Up")
ControlCommand("Auto Position Finger", AutoPositionAction, "Fingers In")
#22
I can see that the AutoPosition control (non movement) can be set to EZB 0-4 but AutoPosition (movement) is defaulted to EZB 0
Is this correct ?
Frank
#23
Yes, all movement panels are EZ-B 0 only.
