Translate— Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key.Try it →
That is what I thought.
But Nothing is impossible for you.
you are the great DJ Sures The Robot Overlord we all know and love.
The impossible only takes you a little longer.
You have proven this time and time again.
I have no doubt that some day we will be able to.
Thank you for everything you do.
We all love the EZ-Robot Products and the Software.
Were you able to get AutoPosition to work on 2 boards like you wanted? I am also building an InMoov and have 2 Lotiny in each arm and a single ezb4 for everything else.
@Holy1 The servo auto positioner control will work on any board (1,2,3,4 etc), not just board 0... Look under settings in the auto positioner control to choose which board you want to use with it... You can have more than one Auto Position control in a project (only one Movement Panel though)...
Thanks for your reply. Yes, I understand you can have more than one Auto Position control in a project.
I should have said, (trying to be more clear) was he able to move 2 different servos attached to two different boards from inside one Auto Position control window.
Like move the eyes on board one and wiggle fingers on the loTiny (board 2) inside the Actions portion of the Auto Position control.
That is creative Alan, I will do some playing around with that. Thanks. I think I am going to need a more powerful PC.
Change the variable in the settings of the Auto Position control.
@DJ, I must be missing something. In the settings, the only Variables I see I can change are Current Action, Current Frame and Is Active.
What I would like to do is in my configuration script:
Now in the Auto Position use the variables not the port numbers.
That's not possible
That is what I thought. But Nothing is impossible for you. you are the great DJ Sures The Robot Overlord we all know and love. The impossible only takes you a little longer. You have proven this time and time again.
Thank you for everything you do. We all love the EZ-Robot Products and the Software.
@rz90208 -
@ Richard R.
It looks like this is not possible.
