Voice Activity Detection icon Voice Activity Detection — Real-time microphone VAD using FFT to detect speech start/end and trigger scripts, with live level graph and sensitivity tuning Try it →
Advice On Using Release() Command
I have a general question regarding the Release() script command. What I would like to do is to add this to some of my scripts after a Sleep() duration command to release some of my servos to save on any unnecessary servo holding strain and also to save on battery power.
But I read in a post somewhere recently (can't find the thread I saw it in at the moment) that using a "release" would cause the EZ-B to brown out and would need to be power cycled, or dis and reconnect the EZ-B's network connection, as this should only be used in an emergency.
I have tried it on a simple servo script to have a servo release at its rest position and it seemed to work ok. But before I go ahead and add more Release() commands to a lot more scripts, can anyone tell me if this would be ok to do, or would it not be advisable? Obviously a don't want to keep restarting the EZ-B every time a servo is released in a script.
Thanks.:)
@DJ... Could that be by any chance be a future script command? ResetServoSpeed(all) or something like that?
@Richard.
The initial poster, posted five days ago and asks about the dev kit, so I'm assuming he is talking about the v4, and glad you saw what my understanding of this subject was. And agree about having a reset command. That would be a nice addition.
@thetechguru.
I'm glad you came in on this Alan, and hope you didn't mind me referring to your post. I too have an init script to set servo speeds on connection. I'll have a play about with this again tomorrow and give the Release Control that DJ mentioned a go.
Sure enough, the reset servo speed button brings all my servos back to life. I then need to re-run my initialization script because it sets them all to speed 0 and I have a bunch of them set to speed 1. Using a ServoSpeed() command in a script does not bring them all back. It will revive some, but not all, but the button does work. (I haven't tried a script that sets ServoSpeed() to 0 and then sets it to 1. That might work.
@Alan, that's why I thought ResetServoSpeed(all) would be a good idea for a script command.... That way you can release, reset all servos in one go and then set your servo speeds back to the way you want them again....
I think ServoSpeed(D0,0) might do the same as the menu button Reset servo Speeds, however you have to use this command for each and every servo you are using.... Hence my idea ResetServoSpeed(all).....:)
@RichardR, Just to valadate your idea; I've wanted a command like ResetServoSpeed quite a few times. I was surprised there was no script command for it scene there is a button on the menu bar for it.
Just starting on my new EZB4 robot with custom pan and tilt fabrication. After I assembled everything, I started testing, works fine till I do a servo release to save battery. No more servo movement when I go back? I learned if I reload or reconnect it works? What has changed? Resetting servo speeds to 0 then higher works if I call it twice? Reset servo speeds button works, but not available in script? Now I am not in a hurry to update CaptainAnn EZB3 which uses many servo release calls! Found this post after thinking about it. I am sure something simple like this will be resolved soon. Steve S
#15
@steve, there is no command for reset all servo speeds so you can try doing it one at a time... Try it and see if it works. There is a button next to panic servo release in the menu (under options) that resets all servo speeds to zero... No need to reload and reconnect....
servoSpeed(D0,0)
servoSpeed(D1,0)
servoSpeed(D2,0)
servoSpeed(D3,0)
#etc
#16
Thank you Richard, I have tried resetting each individual servo speed again to 0 and it worked, but had to do several times till everything worked correctly. I also added the desired speed in script and it worked. I do not understand why we have to start adding all these scripts? I was not expecting to have to do all this w EZB4. I know there are still many more advantages to EZB4, and this will be resolved. Steve S
