Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Adding Wifi To One Of My Existing Ez-b's
Adding Wifi To One Of My Existing Ez-B's
Wednesday, 20 February 2013
Good Morning EZ-B Robot Builders !
How much Code would be required to add WiFi to one of my existing EZ-B's ?
I still want to Maintain ALL the ARC Features, other than BlueTooth !
A most reliable friend guided me to the following Modules :
Roving Networks' RN-XV Wi-Fi Module 30025, https://solarbotics.com/product/30025/
SparkFun XBee Explorer Regulated 50828, https://solarbotics.com/product/50828/
Thank You All For The Consulting Services,
[email protected], 602-246-1246(H)
#33
Glad to read that you got your WiFi board to work via your EZ-B and Roomba.
#34
Glad to hear you got it to work.Still having problems getting it to work with EZ-B but was looking at xbee for one of my other projects and might try it with EZ-B
#35
PITTOM whats wrong with yours,it works very easy I got mine working on the first try.
#36
Also i am about a hour away from the elechouse company where they make them in china So i guess i can call them for help.
BUT i can also solve anything and WIFI is easy for me.
#37
@robotmaker i get wifi to connect but if my hole program is up ezb locks up until i disconnect ezb(robot) then computer is unlocked.
BUT if i have 2 battery monitors up on ezb it does not lockup pc.
this is the error i get when main program is up
Attempting connection on COM7 Connected to COM7 at 9600 EZ-B reports EZ-B Firmware V25.5 Connected Disgard incoming buffer (This should never happen)
my pc is 10 inch aspire one 1.60ghz 2gb of ram
#38
Firmware v25.5? Current firmware is v16.
#39
ok will try update
#40
I think because you have a slow computer,i have at home a ASUS laptop with 1.6 mhz and 2 gig ram and it did lock up on other programs
I dont have EZB builder installed in it ,but in 7 days to 8 days when i return will try it for you.
