PTI Lidar Plugin icon PTI Lidar Plugin — Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement. Try it →
Adding Wifi To One Of My Existing Ez-b's
Adding Wifi To One Of My Existing Ez-B's
Wednesday, 20 February 2013
Good Morning EZ-B Robot Builders !
How much Code would be required to add WiFi to one of my existing EZ-B's ?
I still want to Maintain ALL the ARC Features, other than BlueTooth !
A most reliable friend guided me to the following Modules :
Roving Networks' RN-XV Wi-Fi Module 30025, https://solarbotics.com/product/30025/
SparkFun XBee Explorer Regulated 50828, https://solarbotics.com/product/50828/
Thank You All For The Consulting Services,
[email protected], 602-246-1246(H)
#49
I probably won't be around much this weekend but will respond when I can.
I'll dig out the info on a good freeware network scanner/checker in the morning which will give much better and clearer details on any network issues you may have than windows will ever give you (FYI hover the mouse over the network icon by the clock and it'll tell you speed and strength). If you use team viewer id be happy to take a peek if you're really stuck.
#51
Download the WIFI scanner it tells you everything about your WIFI and range and more and others that are running.
#52
hi all,
can somebody please make a video on how to install wireless to ez-b or a really detailed instructions with pictures for dummies please it seem to complicated for me i need a step by step guide, thanks
#53
If you have an android tablet or smartphone get yourself a copy of fing. It's great for checking out your network. In it you will be able to check the services running and ping any client connected to your network, this will indicate if it's a networking issue if the ping to the WiFi board is high.
Always be careful what you download, more so if it's within a zip and not from the developers website direct. Malware is found in around 90% of files like that. The last thing you want is to have to clean up after a parasite.
Here are a couple of ping tests I just carried out on my network, one is to a Linux box connected via wifi with a bunch of services running the other to my router. Ping of around 5ms is what you are looking for.
If you are getting a ping much higher than that then it is indicating there is a problem with the connection and you will need to check out all settings on both the router and on the wifi module.
Check which services are running on the laptop too, this could indicate what the problems are.
Otherwise, I would say that you have a problem with the module itself. Again check all settings are correct. I recall you were having problems with setting it up correctly in the first place so it is not out of the question that it's been set up incorrectly.
Also check that all routes to and from the wifi module are open and working. Ensure that Windows is not blocking anything through the firewall, that no antivirus is blocking anything and that you don't have any viruses or malware causing the issue.
If you still have problems as I said I would happily help you over TeamViewer or similar, I have a wealth of experience (and qualifications) in networking and I'm sure it's something simple that's not been set up correctly initially.
#54
pittom also save the data and have anyone look at it to see what problem you have.
YES i check the WIFI SCANNER AND IT HAS NO MALWARE or virus
IT DOES DOES MANY CHECKS and has graph
And can save or print the data ,its a small file for all versions of windows ,plus the site has alot more scanners and tools.
I have used it for while on all my computers
#55
Also on malware and virus on downloading a file,its always good to check it with NORTON or good virus detection program before you open it or install it,some have a hidden virus
#56
METEALP97 I can easy make a video only i am on a work trip for 1 week more. HOPE somebuddy else will make a video,its not too hard and should take to long
