Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Adding Wifi To One Of My Existing Ez-b's
Adding Wifi To One Of My Existing Ez-B's
Wednesday, 20 February 2013
Good Morning EZ-B Robot Builders !
How much Code would be required to add WiFi to one of my existing EZ-B's ?
I still want to Maintain ALL the ARC Features, other than BlueTooth !
A most reliable friend guided me to the following Modules :
Roving Networks' RN-XV Wi-Fi Module 30025, https://solarbotics.com/product/30025/
SparkFun XBee Explorer Regulated 50828, https://solarbotics.com/product/50828/
Thank You All For The Consulting Services,
[email protected], 602-246-1246(H)
OK i ordered one about a week ago,from china cant add a wired network to it only
After Midnight Thursday, 14 March 2013
Good Morning EZ-Robot.com Hardware Team !
Last week I received my ElecHouse UART-WiFi Kit, and got it Connecting to my Home Router with help from Robot-Doc, who led me to the TLG10UA03, ElecHouse UART-WiFi ! ElecHouse UART-WiFi
I have attached my Screenshots and Test Procedure, "13-Mar-2013 ElecHouse WiFi UART Serial Terminal Loop-Back Test.doc", and my ARC File of the same name.
I am using DJ's New Serial Terminal within ARC; seems to WORK GREAT, but I need to LEARN MORE on its proper use ?
My Question is, Exactly Where Do I Loop-Back the WiFi Module; I tried Tx-to-Rx with No Success ?
Thank You All & Best Wishes,
13-Mar-2013ElecHouseWiFiUARTSerialTerminalLoop-BackTest.zip
13-Mar-2013WiFiUARTSerialTerminalLoop-BackTest.EZB
DOUG ,your file in backtest zip doesnt open in wordpad or notepad need to check it
It's a word document that's why. The file opens perfectly fine.
Thank You for the Quick Reply !
The File Name is : 13-Mar-2013 ElecHouse WiFi UART Serial Terminal Loop-Back Test.doc , and it is a Microsoft Word File.
It also opens in OpenOffice & Libra.
It is a file of ARC Screenshots using Serial Terminal to Test the TLG10UA03, ElecHouse UART-WiFi !
The Wireless Module shows up Immediately on my Router at Power-Up, COM8 only shows up in Device Manager when I plugin the Included USB-TTL Module.
Serial Terminal requires a COMM Port to connect.
Please look at my Screenshots that are in the order of Bootup, after the WiFi is Powered Up.
We see it in the Router, 192.168.1.119,
on its own Webpage https://192.168.1.119/,
but only in Device Manager on COM8 when the USB-TTL Module is attached.
Thank You For The Help & Support !
#15
I dont use microsoft word,never had a reason to use it,only wordpad and says" unable to load graphics"
wordpad cant load grapics only microsoft,but you can open microsoft word documents in wordpad only wont see grapics
WHEN i get back from my work trip in 3 weeks about will check it out,looking to compare to another WIFI board and add WIRED networking to have both
#16
PITTOM one reason you might be slow is because of the range of your WIFI router ,you need a WIFI booster is one way or if you have WIFI router can make it LINUX with special software and cpu processor in it faster
software is called DD-WRT and its free and how to upgrade most WIFI modems MOST COMMON IS WRT54 ,i got about 25 to modify and sold many of them
dd-wrt SOFTWARE
