Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
ARC Shortcut Creator
Does Shortcut Creator work in ARC?
The Create Shortcut and Copy file path to clipboard are both greyed out and not clickable
Thanks Steve
Lattepanda by DF Robot
LattePanda with Synthiam ARCx runs headless, loads EZB firmware on the built-in Arduino, and controls robots from any browser
Servos 12
UART 1
ADC 5
Digital 12
PS, here's the step by step instructions. Just make sure you remember where the shortcut file was selected to be saved. You might have several in a weird folder that you accidentally selected:D
Hi DJ, and thanks. I did follow the instructions, making sure to use all the default settings as I went thru each step, thats why I am a bit lost, Its not where I thought it should be., even when I did a total search of all drives, nothing showed up.  Yes odd. I will keep looking of course, It has been a long time since I've used this feature.
