Austria
ARC
Hi I'm from Germany also have a EZ - Board V3 + and think it's really cool what you can do with it but unfortunately I have a big problem connecting to ARC . So I connect my bluetooth give 1234 and it connects to the PC but when I select the ARC the correct port the smaller of the two and click Connect comes an error see Screenshot what am I doing wrong that can not be true , I try it already had days I'm very technically gifted eigendlich but that part will simply not connect other Bluetooth dongles have already try with the laptop it does not connect This message comes is the port that right ez - b flashes blue and red LED:
Attempting connection on COM50 Connection Failed: System.TimeoutException: Timeout bei Schreibvorgang überschritten. bei System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) bei System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
Austria
#25
Thanks to all who have worked here and have tried to help me . I As written normal as not to get such big problems around something out but that was really bad .
Austria
#26
What should I do with the ARC update ?
#27
If it works - don't fix it:D
Austria
#28
Have now make one last question I have looked in the projects folder from ARC there is a project from Robosapiens V1 for control over the PC . I found none of the Robosapiens V2 , as much as I know but Robosapiens V2 other IR codes or ? The project from the V1 can not do that ? Or is it ?
Austria
#29
If it works - don't fix it Grin
Ha ha ha :-(
#30
@Optimus If that were true then why do we drive cars instead of riding horses to work?:D Even worse, we could all be using arduinos today if @DJ decided not to make a better robot controller... eek
#31
To answer your question about the robosepian v1 versus v2, wowee changes their codes much to often and so DJ stopped developing after V1.
Austria
#32
yes but when Robosapiens v2 it would be worth the real in the project list aufzunehmen.Er offers many possibilities , it is twice as large robot has many sensors better cross arms and even a USB camera to detect colors of objects ir sensors and movements look really cool when liquid drain so the original joypad controls go , it is difficult and gradually the movements are difficult to program joypad liquid with which he does something it would be but only ir codes that you must change project at V1 or not the ir codes I 've been to the internet
https://www.aibohack.com/robosap/ir_codes.htm
