Hi I'm from Germany also have a EZ - Board V3 + and think it's really cool what you can do with it but unfortunately I have a big problem connecting to ARC . So I connect my bluetooth give 1234 and it connects to the PC but when I select the ARC the correct port the smaller of the two and click Connect comes an error see Screenshot what am I doing wrong that can not be true , I try it already had days I'm very technically gifted eigendlich but that part will simply not connect other Bluetooth dongles have already try with the laptop it does not connect This message comes is the port that right ez - b flashes blue and red LED:
Attempting connection on COM50 Connection Failed: System.TimeoutException: Timeout bei Schreibvorgang überschritten. bei System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) bei System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
here on the website are more codes for all Woowee
https://www.aibohack.com/robosap/ir_codes_v2.htm
I would make the codes from Robosapiens V2 itself at ARC to insert it then instead of the Robosapiens V1 codes to use the ARC is complicated that ?
DJ Sures can the EZ - Builder somehow the IR codes of Robosapiens V1 with the IR code from V2 Robosapiens Replace the IR codes from V2 I . It ought to be possible to replace the V1 with the V2 ?
There are no plans to add the Wowwee robosapien toy to ezrobot platform.
