I'm going to build a wheeled robot and need a servo HAT. I wnat make sure it’s compatible with ARC the Raspberry Pi 5. Is there a spot where I can verify that it has support for the ARC Synthium robotic software ?
svorres
Whats The Preffered SERVO HAT For The Raspberry Pi
Raspberry Pi
by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos
UART
ADC
Digital
Lewansoul Servo
by LewanSoul
Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation.
Requires ARC
v30
SSC-32 Servo Controller
by LynxMotion
ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills.
Custom Servo Controller
by Synthiam
Control up to 99 servos over serial with Vx virtual ports using custom firmware on Arduino or microcontroller controllers.
Requires ARC
v3
For building a wheeled robot with a Raspberry Pi and ensuring compatibility with Synthiam ARC, you should consider using a servo HAT that is well-supported and integrates seamlessly with ARC. Here are a few options and considerations:
Recommended servo HATs for Raspberry Pi:
Adafruit 16-Channel PWM/Servo HAT for Raspberry Pi:
Pimoroni servo 2040:
Verifying Compatibility with ARC:
To ensure that the servo HAT you choose is compatible with Synthiam ARC, you can follow these steps:
Check the Synthiam Website:
Community and Forum:
Custom Integration:
Steps to Integrate a servo HAT with ARC:
Install the servo HAT on the Raspberry Pi:
Configure the servo HAT in ARC:
Test the servo HAT:
Example Configuration for Custom servo Controller:
Load the Firmware:
Configure the Robot Skill:
Connect and Operate:
By following these steps, you can ensure that your servo HAT is compatible with Synthiam ARC and effectively control your wheeled robot using the Raspberry Pi. If you have any specific questions or need further assistance, feel free to ask!
There’s a Kabillion servo hats and as you pointed out, too many to support them all. Mainly because there’s no standard. So if you can share the one you’re looking at, we can let you know.
