Benchmark icon Benchmark — Diagnose EZ-B connection speed and reliability; benchmark ADC read rates (4-70/sec), reveal flood-control effects and optimize data throttle. Try it →
error in speech recognition window
Error In Speech Recognition Window
hi all
am using the speech recognition window .all works except the deactivate line ? whatever vallue i use high or low .it does nothing .i also set the volume on pc higher . i see a message heard but not detected . the tutorial says to set the value higher .
anyone thank you
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence.
Hello Nomad, which speech recognition skill are you using? Do you have screenshots of what you are describing?
hi jeremy
thisone . its the disable frase .
thank you
#3   — Edited
You have two spaces (You hit the space bar twice). You must separate words with one space only to be grammatically correct. Remember, the phrase you enter is matched against what is detected. You can't speak with multiple spaces between words. There is only ever one space between words.
hi dj
indeed it works . lesson learned .
thank you
