Hello,
I've just updated to ARC software. I am getting an error on startup regarding the dynamixels in my project. Is this plug-in working with the new ARC software? I looked and can not find any updates for the dynamixel plug in? Thanks Chris
SSC-32 Servo Controller
— ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills.
Hello,
This is what I get from just double clicking the updated plug in from my desktop. No other programs are running. Thanks Chris
B2K_12_29_2018.EZB
This is my project. Could someone please take a look at it? Everytime I open it its worse. Now i have 7 dynamixels plug ins and now the error says its missing a form. And theres other errors I cant seem to get around. Thanks Chris
I think part of my original problem was I was using IE. After using chrome I was able to get the updated plug ins
Interesting - it says the file isn't a plugin. I'll take a closer look and get back to you
Thanks DJ. If you dont mind please take a look at my project I posted. There seems to be lots of errors I cant fix. Thanks
Chris
The reason the plugin says it's not a valid plugin is because you gave the file a different name when saving it. The file that's downloaded from the server cannot be changed. The original filename must be used. Do not rename the file when you download it from the website.
I think Im past that part. But there are many other errors. I cant even get ARC to close. I have to use the task manager to get ARC to close. Everytime I try to X out the error that pops up another one pops up and I cannot ever close the project
