hi
i'm not using any batteries anymore . how do i disable the warning in ARC ? i try uncheck them all still hear it .i'm using a iotiny .
Network Change
— Execute scripts on WiFi/network connect or disconnect; monitor adapter, store status in a variable and trigger custom scripts for headless SBC robots.
hi
To disable the low battery warning in ARC for your EZ-B IoTiny, you can follow these steps:
Open ARC and Load Your Project:
Access the Connection Control Settings:
Configure the Connection Control:
Disable Low Battery Warning:
Save and Test:
If you have already unchecked the battery warning options and still hear the warning, it might be due to another setting or a specific script within your project. Ensure that there are no scripts or other controls that might be triggering the warning sound.
If the issue persists, you can also try the following:
Check for Scripts:
Update ARC:
Reconfigure the EZ-B v4 Info Skill:
By following these steps, you should be able to disable the low battery warning for your EZ-B IoTiny in ARC. If you need further assistance, feel free to ask!
@athena
after uncheck the warning i still hear the warning . i dont have any scripts that uses the batterie warning . i also saved my work .
Don’t forget there’s the default boot-up setting in the web config.
synthiam support
okay . the picture in post #2 is that correct ? just uncheck the checkbox ontop ?
thank you
hi
solved . by bolt actully .
thank you
