SSC-32 Servo Controller icon SSC-32 Servo Controller — ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills. Try it →
disable low batterie warning
Disable Low Batterie Warning
hi
i'm not using any batteries anymore . how do i disable the warning in ARC ? i try uncheck them all still hear it .i'm using a iotiny .
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
EZ-B V4 Info by Synthiam
Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control.
To disable the low battery warning in ARC for your EZ-B IoTiny, you can follow these steps:
  1. Open ARC and Load Your Project:
    • Start ARC and load the project that you are working on.
  2. Access the Connection Control Settings:
    • Click on the "Project" tab at the top of the ARC window.
    • Click on the "Add Control" button.
    • In the "Add Control" window, navigate to the "General" tab and add the "Connection" control if it is not already added.
  3. Configure the Connection Control:
    • Click on the gear icon (settings) of the "Connection" control to open its configuration settings.
    • In the settings window, you will see options related to the battery monitor and low battery warning.
  4. Disable Low Battery Warning:
    • Look for the "Battery Monitor" section within the settings.
    • Uncheck the option for "Enable Low Battery Warning" or similar options that control the battery warning notifications.
    • Save the settings and close the configuration window.
  5. Save and Test:
    • Save your project to ensure the changes are retained.
    • Test your robot to confirm that the low battery warning is no longer active.
If you have already unchecked the battery warning options and still hear the warning, it might be due to another setting or a specific script within your project. Ensure that there are no scripts or other controls that might be triggering the warning sound.
If the issue persists, you can also try the following:
  • Check for Scripts:
    • Review any scripts in your project that might be related to battery monitoring or warnings. Ensure that no scripts are explicitly triggering the warning sound.
  • Update ARC:
    • Make sure you are using the latest version of ARC. Sometimes, updates include fixes for issues like these.
  • Reconfigure the EZ-B v4 Info Skill:
    • Since you are using the "EZ-B v4 Info" skill, ensure that its settings are also configured to disable any battery-related warnings.
By following these steps, you should be able to disable the low battery warning for your EZ-B IoTiny in ARC. If you need further assistance, feel free to ask!
@athena
after uncheck the warning i still hear the warning . i dont have any scripts that uses the batterie warning . i also saved my work .
Don’t forget there’s the default boot-up setting in the web config.
synthiam support
okay . the picture in post #2 is that correct ? just uncheck  the checkbox ontop ?
thank you
hi
solved . by bolt actully .
thank you
